Question about Dryers
Loose tub on maytag 7600 electric dryer
The tub on my maytag 7600 series electric dryer seems to be loose...it makes a loud clanking noise when running. How do I fix it?
  • 2,005 Answers
The tub bearing needs to be replaced it is on the back center of the drum
Posted on Apr 22, 2009
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Maytag Legacy series dryer making loud noise. Sounds like something flapping.
A common problem on these dryers is the blower wheel itself will wobble out and make noises. Pop the top with a putty knife then remove the front panel. Check the blower housing for looseness.or something in it. I worked on a monkey wards dryer with a bad blower wheel and made crappy movie on my phone:
Sep 04, 2012 | Maytag Dryers
My maytag dryer,model no.DE303 makes a loude clank-a-d-clank noise as the barrel rotates. Sometimes the sound will change and smooth out, only to get lound again. How do I fix this? It still turns and drys...
This is likely caused by a worn-out drum roller. There are two of these which support the back of the drum and allow it to turn smoothly. Replacing these involves taking the front panels off and removing the drum.
Dec 15, 2011 | Maytag Dryers
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
The dryer is making loud noise. Maytag MDE2706AYW
Back tub bearing
front tub felt w/ slides bearing
Belt tension pulley
Rate me if this was helpful
Thanks
Leo Ponder
imufo2@sbcglobal.net
Aug 01, 2010 | Maytag MDE2706 Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Loud noise
could be that one of the bearings that the tub rolls on is wearing out and needs to be replaced or the belt pulley running to the motor is worn and needs to be replaced. Hope this helps
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
