Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Frigidaire 1500 series dishwasher will not wash or rinse
The unit fills and then nothing happens until it drains. Then it fills again before the rinse cycle should come on but again does nothing. The water level covers the filter. the heating element seems to work. the detergent dispenser never opens.
    Brigadier General:
  • 3,614 Answers
After the unit fills for the second wash, open the door and check the level of water in the tub. It will not leak out and the unit will stop when the door is unlatched, then reply with the water level.
When a dishwasher detergent dispenser starts acting up, there is usually a detergent clogging problem present. Rinse out the dispenser cup and try switching to a liquid gel detergent. There also could be a problem with the spring on the dispenser having gone bad. The spring can be replaced by first removing the front panel of the dishwasher, then loosening the bolts that hold the dispenser cup to the dishwasher door.
If the dispenser cup is not spring-loaded, then chances are it uses either a bi-metal switch or a wax motor to disengage the door. These can be swapped out.
A defective timer switch can also be at fault.
hope this helps
Posted on Apr 21, 2009
My Bosch she45mo6uc/50 dishwasher will not advance to the wash cycle. It makes a series of clicks, but nothing happens. It just stops. Any ideas?
The most common problem that causes this with this particular unit is the water heater unit failing. It will clod rinse but then when it fills and tries to heat the water, it senses that the heater unit isn't functioning and errors out
Sep 21, 2015 | Bosch Evolution 500 SHE45M06UC Built-in...
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Trying to start the unit but the washing light indicator only flashes.
this means the machine has started the cycle...that is the washing light is flashing. However if nothing happens then the drain pump is not working firstly. Machines usually drain first any bit of left over water then go yo fill up. As you havent ststed the make and model i assume the drain pump is faulty. or the water inlet is not working. More precise info is needed to advise you further
Aug 01, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Will not go thru cycle/drain once filled
After searching through some of the older solutions, I came across what sounded similar to what I was dealing with. Followed what was suggested, and I have a dishwasher again!!!! :) TY
Cindy
Nov 23, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
460 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
