Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
There is excessive calcium (hard water) build up on the spray arms and it is clogging the arms. I have tried Jet Dry and it doesn't help. How can I get it clean?
    Problem Solver:
  • 7 Answers
You can clean this with a product called Lemi Shine. Find it at your local grocery store. It works amazingly well at removing buildup and keeping your dishes and glassware sparkling clean.
Posted on Aug 11, 2009
Dishwasher not cleaning dishes; water not coming out of top spray arm
You are right to go to the inlet filters. If they are clogged you would lose pressure, but not that much...The pressure pump is probably not outputting any longer. Locate it and see if it is moving freely.
Jan 14, 2013 | Dishwashers
Leaves white layer of film. I use Cascade pouches and Jet Dry liquid. I used a dishwasher cleaner recently thinking that would solve the problem, it seems to have made the problem worse. Thank you
First, check the holes in the spray arms to make sure they aren't clogged. Next, try using a powder or liquid detergent so you can vary the amount that you use. If you have very soft water, the pouches may be way too much detergent for a load. If you have very hard water, it could be calcium deposits. The cure for this would be a water softener.
Feb 14, 2011 | Whirlpool Dishwashers
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
GE nautilus dsihwasher. dishes are not coming clean. Leaves a film on glasses and utensils.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic....
Nov 29, 2009 | GE Dishwashers
Cloudy will not come off when washed by hand almost looked like it looks scratched and and somewhat of a ring look on top and bottom of glass. I have a water softner too.
Oct 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch dishwasher SHU9926UC
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool dishwasher QUIET PARTNER II doesn't clean dishes, leaves film
Aug 15, 2009 | Dishwashers
Dishes have a powdery residue
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
Dishes have a fine white film when useing hard water using rinse
Check the following to combat this issue.
Not enough water
Clogged spay arms
Water temperature is too low
Smoky film on dishes and glasses
The most common issue will be a high calcium build up overtime.
Jun 18, 2009 | Frigidaire Dishwashers
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
Clogged spay arms
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Jun 18, 2009 | Maytag Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
120 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
