Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
Optoma RD50 TV which shuts down on #1 fan failure
I have an RD 50 Optama tv which shuts down after a few minutes of use. I get an error message on the screen that says #1 fan failure. I am looking to find out if anyone knows what the part number is for this #1 fan and what section of the tv the #1 fan is on. There appears to be three fans in the tv total. Anyone with any information regarding this problem, please contact me or post an answer. Thank you for your time.
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Posted on Jun 15, 2009
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
My Optoma HDTV Model RD50 needs replacement of its internal lamp. Which model lamp is the correct one and how much does the lamp cost? Regards - Lee
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
Jan 11, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
I turn on the tv but I get no picture (black screen). A sound starts when I turn on the tv. The sound ( like a humming noise) fan perhaps which goes up and down for about a minute then the tv shuts off and...
Sounds like a problem with the color wheel. Unfortunately the color wheel is located inside the light engine. According to everything I have read, the only thing you can do is replace the light engine. You are better off replacing the TV. The light engines can run form $750 to $1400. Which is ridiculous!
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma TV light Engine or Optical Engine Replacement
Technical Service Corp 888-942-2929 is where you can purchase an optical engine, I inquired for my RD 65. The part cost over $900, not quite worth it.
Hope this helps
Apr 15, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma RD50 Lamp Issues
replace the fuse thats on the little board beside the new lamp. that will reset the buld to new. I understand that the fuse will blow right after a new lamp is installed. It will reset the counter to 0.
Hope this helps
Ron
Dec 30, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
Shadow box/signal block?
Check the closed caption settings. To me that looks like the TEXT mode is turned on.
Feb 19, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
How to fix black shadows appearing on both sides of the screen?
i beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Jan 14, 2007 | Optoma RD50 Television
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
546 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
