Question about Dewalt Saws
Dead dewalt 357 dw357 circular saw
When I plug in my dewalt thre is no power (dead)
  • Eric Wissenbach
    Eric Wissenbach May 11, 2010
    You've tried different plugs,extension cords, checked the saw cord,etc..?
  • 4 Answers
First!!!! unplug saw.remove housing screws to check for a loose connection.second. be sure your outlet has power.
Posted on Apr 24, 2009
Dewalt DW362 7 1/4 CIRCULAR SAW JUST STOPPED WORKING. No smoke or anything.
There might be a thermal overload device in the motor windings that opens in the event of an overload leaving you with a saw that is completely dead.
Apr 03, 2017 | Dewalt Saws
How do I put the dewalt dc390 back in the case?
Have you tried to remove the battery and put it in separately?
Sep 21, 2014 | Dewalt DC390K 18v Cordless Circular Saw...
Dewalt circular saw runs like power lacking intermit ant
The armature is bad. A new armature is about the same cost as a new saw. Buy a Milwaukee next time.
Mar 14, 2014 | Dewalt Saws
User manuel for dewalt dc390 battery powered skillsaw
Go to http://servicenet.dewalt.com/Home, put your model number in the 'Find Parts' box and hit search. There are two types of your saw, DC390B and DC390K, select the proper one and you can view or download the parts breakdown or instruction manual.
Dec 29, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
I have just brought a new dewalt dc390 cordless circular saw and it seems that the motor is running backwards?
It is possible that the motor is running backward but... first see the manual here:
http://www.plumbersurplus.com/pdf/08364.pdf Make sure the blade is installed as pictured in figure 4 page 11 of the manual.
After seeing the manual..... make sure the battery is charged correctly. The flat side of the battery should be toward the back of the charger when charging. If somehow the battery was inserted backward in the charger it is possible the battery was reverse charged during the intital charge. If you suspect this has happened.... insert the battery in the saw and run the saw until the battery is DEAD. Then insert it properly in the charger and leave it there for 9 hours so the charger will do the automatic tune up equalization of the battery.
If none of the above correct the problem, someone connected the internal battery power wiring incorrectly during FACTORY assembly. I would take it back to the retailer first... before processing a warranty claim.
You can contact DEWALT here:
call 1-800-4-DEWALT
(1-800-433-9258).
Thanks for choosing FixYa,
Kelly
Apr 30, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
I have a DW357 circular saw. It is running backwords???
It shouldn't be for no reason...... Check that the blade is spinning over the top and down into the wood in the line of travel. Is it possible that the blade is on backwards?
Best regards, --W/D--
please feel free to rate this solution. thanks.
Feb 05, 2011 | Dewalt Heavy Duty 7 1/4" Circular Saw
My DW384 circular saw keeps tripping the GFI receptacle
Most houses have all the outdoor GFI outlets on one breaker...perhaps you can try another power tool with a similar draw to check if it is your saw or the GFI causing your problem. I can't see bad brushes causing a breaker to trip... the saw would just stop working.
Jun 20, 2010 | Dewalt 814 Inch Circular Saw
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
How to check if coils are open on dewalt 705 mite saw thank you charlie
Measure with an ohmmeter across the AC input line cord with the saw disconnected from the wall socket but turned on. It should measure pretty close to a dead short.
Dec 24, 2009 | Dewalt Saws
Saws Logo
192 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
