Question about Intel Motherboard
Memory chips My computer uses PC266 DDR memory chips,my problem is that there's no available in the market today.Can I replace it with PC333 or PC400?
  • nhar Nov 13, 2007
  • 94 Answers
No motherboard is compatible with all kinds/models of memory chips. If you want to know and make sure if PC333 or PC400 will run in your motherboard, check the manual of your motherboard if you still have the manual. You will see there the memory model that you can use to your motherboard. If you dont have tha manual, search it in the internet the model of your motherboard and its specs. You can also find your manual in the website of your motherboard brand.
Posted on Aug 01, 2009
    President:
  • 2,961 Answers
You can use PC2100, see below for example http://www.amazon.com/Memory-Upgrade-PC266-PC2100-AA32C12864-PC266/dp/B00009OYBA
Posted on Sep 21, 2007
  • 1 more comment
  • andrew pester
    andrew pester Sep 21, 2007
    Sorry, but whats the problem, you have to use PC2100, but because you can't replace it with PC333 or PC400 as you mentioned does it make my solution wrong?
  • andrew pester
    And the memory is available!!
  • andrew pester
    andrew pester Sep 24, 2007
    please rate the solution, thx
I have heard that a PC333 DDR ram can also run in a PC266 DDR ram supported motherboard but in a "slower speed", what does this mean? Let's say that If I use a 512MB PC333 on a PC266 DDR Ram...
You will get 512 Mb of memory but it will run at the slower bus speed. Think of it like this. Your memory is your car. Your car has the ability to go faster, depending on how fast the motor allows it to go. Unfortunately, everywhere you drive has a speed limit. Regardless of how fast your car CAN go, you are only able to drive the speed limit. That's kind of what is going on with the bus speed situation.
Bus speed determines how fast the memory and cpu can transfer data between one another. The higher the bus speed, the more information it can transfer at a quicker rate. If your memory is capable of transferring at a rate of 333 MHz but your motherboard can only support 266 MHz you will surely have the 512 Mb of ram but it will only transfer at the motherboard supported speed of 266 MHz as opposed to the full speed that the memory is capable of.
Hope this helps. If it did help you, please give it a thumbs up.
Aug 24, 2011 | Gigabyte Computers & Internet
I have inserted a 1 GB mamory modual and the system is not reconizing the additional memory. Are there jumpers or switches that need to be reset?
No jumpers or switches need to set. If your going to upgrade/change your memory, just make sure that the memory your're going to insert are compatible with your motherboard. Check the system bus of your memory slots if what are the maximum system bus can support of that motherboard. Like example; DDR PC266 to PC400 or PC400 to PC800, make sure that you are not exced the maximum requirements of the memory for your motherboard it is because they cannot recognize your memory.
Jun 03, 2010 | AOpen s661FXm-7US (918EM10S6G) Motherboard
Getting POST Error "Beep" message (3 Long); on a Gateway 500SE Desk Top with an Intel (Nimitz 4000792) P4 1.8Ghz CPU . Can't run machine to ascertain BIOS; thus to determine that manufacture's unique POST...
Dear Frind i think your second ram 512MB Have PC400 Buss Speed, I think also *********** board doesn't support PC400 buss Ram, Please try Ram with PC266 Or PC333 Buss speed. Best Regards sumon
Mar 20, 2009 | Computers & Internet
Memory card upgrade
no! PC266, you can change them to CP3200.
if the clock on the motherboard is adjustable, you may able to get away with PC400. in general, it is not a good idea to do that.
Nov 03, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard upgrade
dont mix your pc400 to the pc266.
Feb 16, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
RAM Support
if it works there is no problem, as the system would not boot up, but your memory will run at the slower of the two speeds, which will be PC266 and not PC333, as the faster speed ram is backward compatable because it always runs on the slowest speed.
Jul 30, 2007 | EliteGroup P4VMM2 Motherboard
Memory Issues
PC2700 (DDR333) memory and PC3200 (DDR400) are backward-compatible with PC2100. Memory is designed to be backward-compatible, so generally speaking, you can safely add faster memory to a computer that was designed to run slower memory. However, your system will operate at the speed of the slowest module or system component (the "lowest common denominator" effect). One thing to keep in mind is that the memory does need to be the same type-for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. Let me know if you have any questions. Good Luck, Tim
Mar 01, 2007 | ASUS P4GE-MX Motherboard
Actually i just want to ask. :-)
Yes but they will both run at the slower pc333 speed.
Feb 19, 2007 | ASUS P4GE-MX Motherboard
Intel Motherboard Logo
107 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
