Question about Garmin GPS 12XL GPS Receiver
Garmin gps 12 wont turn on.
I have 3 gps 12s that went dead while plugged into the 12 volt power supply on my boat.ihave used the 1st unit that went dead on 3 other boats with no problem. i have run + and - to power supply direct from battery.
i have 2 humminbird units and 2 lowrance units with no problems.
the gps 12 is small but great for tracking where you have been,great for trolling.
can they be fixed.
  • 59 Answers
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Posted on Apr 25, 2009
Have a six month old StreetPilot 7200 and the 12 volt cable stopped working. Unit apparently gets no power. Works fine with 120 V AC cable. Garmin says they have no parts for this unit. Is there a simple...
First, make sure that the unit really does run off of +12V. Most Garmin units really run off of +5VDC and there is a charger/regulator that reduces the +12VDC to +5VDC. Look at the power cable and see what the output voltage is. Does the unit has a USB port?
Oct 13, 2013 | Garmin StreetPilot 7200 GPS Receiver
Garmin nuvi 745
Yes, a Cellphone, Google Maps and a Power Block will give you about 5 days use!
You could also carry a small 12 volt lithium battery of the type used in alarms in a back pack, connected to a cigar lighter like this unit.
12VOLT RECHARGEABLE PORTABLE BATTERY POWER PACK 12V DC CHARGER LIGHTER...
Or this
Lightweight 12 volt portable battery station Lithium ion 8 8 Amp Hours...
Or you buy a GPS Sat Nave unit specially made for cycles.
Cycling GPS Units Amazon co uk
Garmin Edge 1030
Garmin Edge 1030 GPS black 2018 handheld colour gps
Nov 18, 2017 | GPS
Charged garmin forerunner 110 with 12 volts for split seconds and won't turn on anymore?
Power supply damage is most likely and depending on cost of the unit itself may or may not be worth fixing---kind of like hooking a radio up backwards on a 12 volt system--damage is INSTANT and sometimes fatal.
Dec 04, 2012 | Garmin Forerunner 110 GPS Receiver
Garmin wont turn on
Try charging it, if not plug it onto the Garmin updater manager and update the device software.
if still not working, ask a specialist in the sat nav store they should give you all the details and paperwork to help
Sep 27, 2012 | Garmin Nulink 2390 Gps Satnav Uk & Europe...
My Lowrance unit gives me a message of
Hi check the receiver has 12 volts at the blue plug, if so the mushroom is most likely fried, regards Phil.
Jun 10, 2012 | Lowrance LGC-12S GPS Receiver GPS Receiver
I just installed a 595c gps on my boat. I used it the first time with no problem. The next time I went out, it would not start up. The power comes on but only 2 symbols show up on the left hand side of...
If you know of someone else that has the same setup on there boat you can slide your unit on there mounting system and see what you get. This will tell you if it is the unit or the transducer. I would check my voltage to make sure you have 12 volts at the end of your power cable. If you do not know of anyone with the same setup you can contact our Customer Group and they will be glad to help you out. There number is 800-633-1468.
Thanks
Joby @ Humminbird
Jan 04, 2011 | Humminbird 595c GPS Receiver
Need to know how to connect the 12 v dc power to the unit as I lost my power cable for radar 1000
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
Oct 14, 2010 | JRC 1000 MKII Radar GPS Receiver
Have everstart 24dc-6 boat battery is it 6 or 12 volt
From your discription it's a 6 volt
Dec 31, 2009 | Boating
Where can I find a wiring diagram to install a generator into a boat? I know how to wite the 110 volt side but where do I connect the 12 volt power from the generator into the 12 volt distribution panel?
Installing a generator into a boat is critical to be done correctly. You need to contact the manufacturer of your generator for approval, and wiring diagrams. If done incorrectly (which if you are connecting 12v from gen), you may create eddy fields that can cause galvanic corrosion, not to mention electrical shock hazards.
If your generator isn't marine rated, then don't install it into a boat.
Portable generators can be used, but don't hardwire those into a boat. Just use extension cords to the appliances you want to power.
Nov 22, 2009 | Northern Tool Electrical Supplies
Ihave aproblem with a435i gps unit, the other week my boat battery failed which caused weird things to show up on the screen,now the lat/long readings and sog in nm are frozen in time with nothing changing...
On Sat 21 Nov I disconnected the unit and checked to make sure no pins had snapped off inside the connection port, I then connected the unit to a spare power cable in the garage(it has an in-line fuse and ac adaptor fitted), powered on the unit then scrolled thru the various menus powered off unplugged the unit, then re-connected it back in the boat and went for a cruise up the local river yesterday Sun 22 Nov and the unit worked fine, so my guess is a good as anyone's as to how it was fixed, most electrical appliances have gremlins of some kind, could have been low power from the old battery(replaced it), I definately checked and re-checked the connection though, mine are covered in vicks vapour rub (a suggestion from Navcom - local dealer for raymarine).cheers and many thanks
Nov 19, 2009 | Raymarine GPS
Garmin GPS 12XL GPS Receiver Logo
495 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
