Question about Epson Stylus RX500 All-In-One InkJet Printer
Epson RX500 won't turn on
I have had my printer about 3 years. I used is off and on. Before we moved I was having a problem turning on the printer. It would start to come on but then turn off. I tried the On, Load/eject, color, b/w, stop recommendation. I think it worked once and then went back to it's originial problem. I moved over the summer, unpacked the printer last night and it was working again. When I tried to turn it on this morning it had the same problem. I tried the On, load, color b/w, stop option again but to no avail. I did run the Epson's website to run it through the troubleshooting recommendations but nothing helped. Help! I'm ready to toss this thing!
  • 2 more comments
  • Anonymous Dec 29, 2007
    I have the same problem. Where you able to fix it?
    Thanks
    joe
  • sacjoe Dec 29, 2007
    I am having the same problem. Does anyone have a solution?
    Thank you very much.
  • Anonymous Jan 10, 2008
    I am having the same problem, and mine can't be because it's worn out. Though we purchased this product a couple of years ago, we're just opening the box and trying to use it for the first time. I called Epson and they told me it was a "hardware failure" and it should go to a service center. Oh, well, I was hoping for an easy fix too, darn it!
  • Anonymous Dec 30, 2008
    Same thing....my Epson RX500 won't boot at all. This is only after 2 years of use.
  • 29 Answers
Sorry to say, if there is no power - then that's it! Nothing else you can do other than replacing the unit. To be honest, a 3-year lifespan out of any inkjet printer is typical.
Posted on Sep 22, 2007
6ya staff
SOURCE:
Need to remove queue error from Dell PC & Epson RX 500 printer
I would uninstall all versions of the printer and reboot the PC. Check that no remnants of the printer software are left on the PC and then re-install the printer. Use the CD that came with the printer when installing.
Jan 19, 2014 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus Photo RX500. I was cleaning print head when I got "printer error" message. The load eject light is on. I've unplugged printer, turned it on and off. no luck. solutions?
Press all these buttons:
Power+Load/Eject+Stop+B&W+Color
When printer turns ON, "Init eeprom" appears
Release and Press the Color button.
Jan 06, 2010 | Epson Stylus Photo RX500 Printer
A child moved the head in my Epson Stylus Printer
Turn the printer off -- listen for noise as the head should move to its "parking" position.
Turn the printer on, and listen for noise.
If none, then the mechanics that move the head are broken.
Is the printer still under manufacturer's warranty -- although the warranty may _not_ cover child-inflicted breakage.
Sep 18, 2009 | Epson Office Equipment & Supplies
Scanner error
Press the On button to turn off the Stylus Photo RX500. Unlock the transportation lock. Make sure that all packaging materials have been removed. Turn on your Stylus Photo RX500 again. If the error message still appears, call Epson so they can replace your printer.
Goodluck.
sherlyn C.
May 23, 2009 | Epson Stylus Photo RX500 Printer
Turning on the device ERROR
Try resetting the EEPROM
Turn the printer off.
Hold down the Stop, B&W, and the Color buttons.
Press the ON button.
The LCD screen should flash 3 times.
Release the Stop, B&W and Color buttons
Press the Color button again.
Then turn the printer off and back on.
Nov 01, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX500
Turn printer off.
Sep 17, 2008 | Epson Stylus RX500 All-In-One InkJet...
The RX500 prints only one color or two
See my previous posts about intensive cleaning and you should be good to go again: http://www.fixya.com/support/t138226-printer_not_printing
Jun 28, 2008 | Epson Stylus RX500 All-In-One InkJet...
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX500 All-In-One InkJet Printer Logo
1,447 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
