Question about GE Spacemaker JVM1640SJ Microwave Oven
Surface lights are not turning off and stay on Bright. Any thoughts on how to fix this?
Surface lights willl not turn off or dim. They are stuck on bright.
  • Run_away_llo Apr 22, 2009
    actually if you do a quick cycle through bright dim and off 3 times it reprograms it. found it out playing with it
  • Anonymous Mar 19, 2014
    surface light will not turn OFF. It stays on.
    Scholar:
  • 126 Answers
Unfortunately they are controlled by the circuit board and it is not repairable. The board will have to be replaced.Depending on age of unit you should call manufacturer and see what they say < might repair free>
Posted on Apr 22, 2009
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
I have a GE micro ange hood Model# HVM1540DM1BB, bulbs blew,change them out, now the lights will not shut off. I have powered it down over night, pluged it back in next morning same thing. Any ideas
There is a possibility that the light relay is stuck on. Sometimes a sharp tap on the relay will fix it. If not the control board will need replacing.
Sep 26, 2014 | GE Microwave Ovens
SCA1001KSS Surface light stays on
The service manual is here.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
If you have the older version of this model, the problem will be on the main smart board, but if you have the revised version, you would need to send in your "sub PCB", too.
If you need further info, please e-mail us below.
Aug 30, 2012 | General Electric SCA1001KSS 900 Watts...
I have a GE Microwave oven model JVM1790SK01. The surface light switch doesn't work - the lamp stays on all the time; won't dim to night light and won't turn off
There are wires going from the main board to the surface lamp and turntable. They are thin orange, yellow and blue wires. I think the surface lamp is yellow and the turntable wires are orange. You should first try taking the bottom cover off. There are about 8 screws under neath and the bottom cover hinges on the back edge, just let it hang. You can now see the wires. Those wires short to the case where they go through from the main board to the lamps or turntable motor. You now have to move them away form the case. Sometimes they get pinched to the metal cabinet by the lamp socket area. Look for signs of pinched wiring there at the lamp socket or where they go through. Move them away, tape up the bad area.
Mar 21, 2011 | GE JVM1790 1000 Watts Convection /...
After turning the bright light on above the stove
You may have shorting keypad or a problem on the control board.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply back directly to me for free help and tips.
Please include your full model number and color.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 05, 2009 | Kenmore 62622 Microwave Oven
When i pushed button to turn on surface light i heard a pop, thought it was just the bulb but now microwave tray doesnt turn and it seems there is no fan or noise when i turn it on. it still gets hot...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jul 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Same problem
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
prototech@usa.net
Jun 11, 2009 | GE XL1800 1100 Watts Microwave Oven
When new microwave is turned on, the lights in the kitchen dim.
Sounds like your microwave's outlet is on the same circuit with the lights.
High-current devices like microwave ovens should be on their own breaker if possible.
If the dimming is very slight, it may be okay.
If it's considerable, it may be a good idea to run a separate line to the microwave's outlet - especially if it starts blowing your breaker!
Feb 04, 2009 | Samsung MW5351G Microwave Oven
Spacesaver XL1800 Nite Lite will not go off
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site,
linked here on Fixya: http://tinyurl.com/yzjozk
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
787 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
