DISK DRIVE when i,m on my computer it freezit up and then it comes back up in about 5min ,it has been doing it ever since i have had it . i bought it on 2/19/08
This is causing because of the loose power connections of the pc. you can also notice that when your system freezes the hard disk light will be continuously on,
first remove all the connections then plug in only main motherboard powersupply(atx 24 pin or 20 pin).
then attach only hard disk no cd or dvd drives. then remove the ram and interchange if you have two or more.
power up system and check. if it is ok.
then you can plugin all your accessories.
hope this helps
Posted on Apr 21, 2009
TEAC DV-W28SL
Is the replacement drive a new unused drive from the factory or did you purchase it from another supplier? Just off hand, I'd say it's not the correct drive for your system. Laptop drives do not have jumpers to designate what drive it is (like desktop drives do). They come from the factory pre-configured and have no way to change from say master to slave, or cs.
Apr 08, 2014 | Teac Computers & Internet
Hello, my name is Thomas, im not quite sure that matters but, i bought a new WD hard drive about 4 months ago, after i bought a 160 GB hard drive a few years back. I'm very pleased with WD hard drives and...
Externals can be a pain. Mainly because of their casings that can cause failures to happen for no apparent reason. If your warranty will be expired and/or the drive is not showing in "Computer Management - Disk Management" I would suggest removing the casing from the external and plugging the hard drive you've extracted from the case into a desktop.
If the drive is still not recognized after being installed into a desktop I would look into data recovery. My personal favorite data recovery software is Knoppix which is an OS(linux) booted from disk.
Sep 26, 2010 | Western Digital My Book Essential Edition...
I bought this 1 iomega white external drive to back up my pictures, Now the computer is not detecting it, i have already plug it in another computer and Nothing, I have very valuables pictures inthere and...
Disassemble the casing, and disconnect the USB-to-disk-drive adapter from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some computer. If you are "lucky", the computer will detect the drive. If you are "unlucky", search online for "Data Recovery Service" -- these are high-cost services that can disasemble your disk-drive, repair it just long enough to copy your files onto another disk-drive (or DVD-writable media).
Jun 15, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I had a problem with the hard drive and I bought a
when you are installing xp, just after first restart go to bios and set HDD as first boot device
Jul 10, 2009 | HP Pavilion ze5170 Notebook
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
Restore acer to factory default
If you do not have a disk which comes with some computers, here is what you can do→
This is called a "system recovery"
My windows XP, was already loaded on my computer, when I bought it. These instructions, will clean everything off of your hard drive, so you must back up anything that you want to save. I have done this three times, and I got these instructions, from a computer tech. When starting your computer, tap the F-10 key. click on next-yes-and follow the instructions, that come up on your screen. When you are finished, your computer, will look just like it did, when you first bought it. Do these steps, in order, when finished.
1. set up windows firewall
2. windows update (click express)
3. install your anti-virus program (update)
4. install anti-spyware (update)
5. Install service pack 2..3..Good Luck..
All your drivers etc. will reload on your computer, without a disk. All this information is stored on a hidden partition on your hard drive.. Good Luck
Apr 04, 2009 | Computers & Internet
E recovery not recognising a blank disk
First try doing a restore to an early date. I believe that  the softwware for rwadig the CD may be damaged also.
Jan 24, 2009 | Acer Aspire 5004WLMi Notebook
I have a 20X Memorex multi function disk drive and have from time to time tried to use it for backing up/storing important data. My question is if I "verify" the burn there will be errors. I have also...
As for your question of disk vs hard drives, DVD's and CD's that are burnt from a computer are more easily damaged then hard drive data. The best idea if you are looking for a good backup solution is an external hard drive in my opinion. There are many opinions on this very subject so you will receive many opinions. There are no wrong answers just opinions and personal preference. Another solution you can try is an external HD using a program such as Symantec Ghost and create a full image of your hard drive.
Dec 18, 2008 | Computers & Internet
DV1000 Shut Off For The 4th Time
1.when this situation occurs remove the battery and insert after 1min.
2.now start again
3.if it does not start now again remove the battery and also RAM after 5min insert both again
Feb 17, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
