Question about Frigidaire FDE546RE Dryer
How to get the back off a FDE 546RE and replace the belt ?
  • Frigidaire Master
  • 3,361 Answers
You do not remove the back.
Raise the lid and remove the front panel. Then replace the belt.
Posted on Apr 20, 2009
Unfree it when its stuck by paper?
Gene:
If the shredder is stuck that badly, unplug it and use a phillips screwdriver to open the plastic shredder head. Once you get the plastic shroud out of the way, you'll be able to get to the shredder rollers and clear the jam.
Oct 25, 2014 | Office Equipment & Supplies
I can't find where the fuses are on model FDE/FDG336RE
There is no thermo-fuse on this model, only a cycling and safety thermostat.
Oct 08, 2013 | Frigidaire Dryers
How do you remove the front of a Frigidaire dryer, model FDE FDG648GF? I was experiencing a squeeking sound for about a month. Now it has gone from Squeeking to a scraping sound.
this link will help you get into the dryer, http://www.applianceaid.com/wwf-howto.html and this one will assist you with noise problems http://www.applianceaid.com/ww-and-mc.html#noise if you need help after checking these items out, feel free to reply to this answer, and I'll help you through anything you need to know ,
Aug 07, 2011 | Dryers
I got seagate 250gb momentus hdd which show 0mb in bios. how to rectify this error.
This is a know problem you can fix it yourself. http://howto.starahead.com/?p=61
but its tricky better to have this guy do it. http://www.allenwan.com/SeagateHardDrive.php
Jul 15, 2011 | Seagate Momentus 7200 FDE.2 250GB SATA/300...
Gpedit.msc not working in winxp
Click here to download English gpedit for windows XP and follow the below mentioned steps:
Extract the downloaded file and put the below mentioned file
appmgmts.dll
appmgr.dll
fde.dll
fdeploy.dll
gpedit.msc
gpedit.dll
gptext.dll
into %SystemRoot%\system32 folder (most often it's just c:\windows\system32)
Now, put the below mentioned file
system.adm
inetres.adm
conf.adm
into %SystemRoot%\system32\GroupPolicy\ADM\ (create if this folder doesn't exist)
Finally, run these commands one by one in the CMD window:(Start>run)
regsvr32 gpedit.dll
regsvr32 fde.dll
regsvr32 gptext.dll
regsvr32 appmgr.dll
regsvr32 fdeploy.dll
That should make gpedit.msc callable as Start -> Run -> gpedit.msc
Thanks and regards,
Jitha
Dec 13, 2010 | Microsoft Windows XP Professional
How do you remove the back od dryer to get to the drum? Model # FDE/FDG336RE
you dont remove the back the drum comes off with a pop up and out of the plastic roller in the back or 3 philips head screws in the rear of the drum
Nov 07, 2010 | Frigidaire FDE336RE Dryer
Electric FDE/FDG647RF Drum Loose - Wobbles - Clothes hang at gap at bottom and tear. Can the drum be tightened?
The drum has three parts (depending on your dryer) all of which you can check. Under the drum to the front there are two felt pads that the drum rides on check to see if they are bad, although this more than likely will not make the drum loose. Next I would check your drive belt, if it is stretched the drum may be loose. There is also a bearing behind your drum, you may have to remove your drum to get to this and it is usually screwed in from the inside of your drum. If you can get the upper deck of your dryer off (for regular dryers if you remove two screws on the inside of the door the deck will tilt back on hinges) you should be able to view the top of your drum with the belt over it. Grab the back of the drum and try to move it left and right, if the bearings are bad enough there will be a lot of play in it.
May 10, 2010 | Dryers
I need the driver for your momentus 5400.2 hard drive
U have install all drivers properly in ur hard drive it can be work properly
Jul 11, 2009 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Two part dard drive
Assumed solved. No reply to clarification request.
May 15, 2008 | Lenovo 160GB FDE 5400rpm SATA for ThinkPad...
Dryers Logo
140 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
