3 Compressor in 6 years. Is this normal? As a consummer iam left with no warranty and support...
I have a Fujitsu heat & Cool reverse cycle ASU12R1A with AOU12R1 wall mounted system. I bought this unit in 2003 in Canada from a Fujitsu retailer. On May 2006 the system went down. It was determined the compressor failed. The unit was fixed under warranty. The system went down again Dec 2006. Same issue repeats itself including coverage for warranty. The system fails again April 2009. The retailer claims that the system is down again because of the compressor, which is not covered anymore. The retailer claims that Fujitsu is not responsible anymore? I have written to Fujitsu for assistance in this matter and waiting for a distributor to contact me. Questions: 1. Is it normal for a Compressor to be faulty 3 times in 6 years ? 2.Is there a recall that I should know about? 3. Is the retailer possibly responsible for wrong dianostic, and where does this leave me? I will ask the same questions when a Distributor from Fujitsu contacts me... Thanks Jacques Croizet 116 Chemin Vigneault Cantley, Quebec J8V3A6 819 671 7064 croizetj@videotron.ca
    Guru:
  • 588 Answers
Multi-Compressor Failures
1st time a compressor fails the service tech is suppose to determine the cause of the
Failure and fix it. Is it no oil return or oil being washed out of compressor do to low sump superheat,
liquid slugging do to thermostatic expansion valve or orifice flooding compressor,starving
for refrigerant do to thermostatic expansion valve or orifice not supplying enough refrigerant to keep the compressor cool, or is the reversing valve shifting properly or electrical,such as bad defrost board, capacitor,relay or electric component or connection, etc.
With multi-compressor failures until you determine the cause and fix it you will keep having this problem
And when a heat pump compressor fails if it’s a burn out, such as electric short or long running at high temperatures and pressures or low on refrigerant level not enough cooling back to the compressor, Causing the refrigerant to break down and create an acid. You need to check the oil in the bad compressor to see if there’s acid in it, then replace the compressor, reversing valve, accumulator (the oil and contaminents will accumulate here and you can‘t get it out), thermostatic expansion valve or orifice, liquid drier, suction line filter drier (if it’s on the lineset outside of the unit then you need to put it inside the unit as close to the compressor as possible).
And after running the system for a couple of days, then the liquid drier and suction filter should be replaced again, depending on how bad the burnt out was or if there‘s acid still in the system you might need to replace them again.
It’s hard to say who would be responsible but there’s something other than the compressor causing the problem and you need to find out what it is.
Posted on Apr 25, 2009
I have a reverse cycle 4 year old fujitsu air con and when I turn it on it automatically just blows air not cold air - it seems to divert to sleep almost immediately can u help.
It should still be in warranty as Fujitsu usually goes for 5 years. Get in touch with Fujitsu to find a local warranty agent. There's not enough info in your post for a diagnosis. Are the lights flashing? If so, what sequence are they flashing? Does the indoor unit otherwise work normally in 'fan' mode? What model do you have?
Jan 13, 2018 | Fujitsu Heating & Cooling
Fujitsu ASTA12LCC WILL NOT HEAT OR COOL. GREEN TIMER LIGHT FLASHES TWICE AT INTERVALS. FAN WORKING. IS IT REPAIRABLE?
Serial signal reverse error. Basically the outdoor unit is not talking to the indoor unit. This is normally due to damage to the outdoor controller PCB and it needs to be replaced.
Jul 03, 2017 | Fujitsu Heating & Cooling
Reverse cycle air conditioner cold winter
Slightly knock on the reversing valve, without breaking anything.
Dec 04, 2013 | Hitachi Heating & Cooling
Why did my ac quiet blowng heat
Check the controls, this unit most likely a reverse cycle air conditioner. It can be set to cooling or to heating. The conpressor is reversed to heat or running normally to cool.
If it is not then the compressor is not working and it is just blowing room temperature air.
Apr 03, 2012 | LG Heat cool Window Air Conditioner
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
I have a fujitsu asta18lcc when you turn it on there is no operation. The louvers open and the timer and operation lights blink 5 times then there is a 6-7 second pause then the cycle repeats
Below is an extract straight from the fujitsu service manual:
Compressor location error
The compressor speed does not synchronze with the control signal. (Including start up failure of the compressor).
> permanent stop.
[Diagnosis Point]
Check if 2-way valve or 3-way valve is left open.
Check the compressor (Winding resistance value, loose lead wire).
Refrigeration cycle defective (Refer to after mentioned "refrigerant cycle diagnosis")
May 13, 2010 | Fujitsu 18C1 Air Conditioner
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Dec 08, 2009 | Heating & Cooling
Normal in cool cycle, very high pressure in heat cycle
Expansion valve on the condensor or possibly overcharged with refrigerant?
Nov 01, 2009 | Goodman Heating & Cooling
Unit never used--won't cool
I would call and get a couple other estimates. If it has never been used, the compressor is probably not bad.
Oct 21, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
196 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
