Question about Pioneer Elite DV-46AV DVD Player
Pioneer elite DV46 AV DVD player suddenly won't power up
No preconditions 2 years old low usage  played fine moments before no surges etc
4 Suggested Answers
  • 518 Answers
SOURCE: Pioneer DV-260 DVD player cannot play HD DVD
Nope. :)
Geno
Posted on Feb 17, 2008
tech48
  • 624 Answers
SOURCE: pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Posted on Dec 12, 2008
wiqi546
  • 1511 Answers
SOURCE: pioneer dvd player 410v freezes when I play avi
I Guess your DVD Player doesn't support the avi format.
If doso, then with some limited audio/vedio rates.
You could read this CNET Review Here about the support.
Posted on Jul 19, 2009
Why do i have no audio or faults.
1. speakers not attached correctly.
2. power not turned on
3. volume turned too low.
4. blown fuse.
5. blown power transistors.
6. antenna not connected properly
7. wrong selector switch pressed, receiver in wrong mode.
Given that you've provided no information at all as to whether the unit was working properly previously; if the unit stopped working while it was playing; whether the unit was fine until the last time you powered it off; anything you did prior to the unit not working such as disconnected the system and reconnected it again, etc. the possibilities above may provide your solution.
If the unit is producing an error code, get a copy of the manual and look up the error code.
Otherwise, the unit may need to be repaired.
Apr 13, 2015 | Pioneer Elite VSX 51 AV network receiver
Sharp lcd DVD error
Suggestion. Check the battery in the remote
Mar 21, 2014 | Sharp LC Televison & Video
My subwoofer stop working
I have a Sony 46" LCD TV. I have a Direct TV HD converter box, a Sony Blu-Ray BDP-S360 Blu-Ray player, and a Pioneer DVD-Audio player connected to my Pioneer Elite Home Theater receiver. I have my Pioneer DVD-A player connected via Fiber-Optic cable. When i play a DVD or a DVD-A on my Pioneer DVD-A player, all of my speakers work fine, but when i play a dvd on my blu-ray player, all the speakers work except my subwoofer. How can I fix this problem?
Jul 03, 2009 | Aspire Digital AD-225PSC Subwoofer
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Denon dvd 2910 locked up
You will have 2 choices here, replace it or have it repaied
Jul 06, 2017 | Denon DVD-2910 DVD Player
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
Play back
Hello I have the D1 and it can not play DVD's in the DVD Rom slot. It is only for use with the DVD Navigation Discs. To watch DVD's on the AVIC-D1 you need to get the Pioneer DVD Player or DVD Changer and connect it through the IP Bus and AV Bus to control it from the head unit. The other way to watch DVD's on the D1 is to buy any automotive DVD Player, for example Boss, Lanzar, etc. or use a PS2, PS3, or any other Video Game System that plays DVD's and connect it through the RCA AV Video and Audio inputs. I believe that the AVIC-D3 has the ability to play DVD's from the unit. It can also can play DVIX DVD's. Hope this helps.
Oct 29, 2007 | Pioneer AVIC-D1 Car Video Player
Teac dvd player
how old is your machine? if old enough isuggest you change the lens and try if it can load faster than before
Aug 01, 2007 | Teac DV-3500 DVD Player
Pioneer Elite  DV-46AV DVD Player Logo
29 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
