Question about HP OfficeJet V40xi InkJet Printer
Hp 1200 white lines are coming
    Sergeant:
    Champion:
  • 293 Answers
PRINTING PROBLEMS CARTRIDGES CAN NOT BE DETECTED PROPERLY Remove and return the Carts on the Printer do this twice then Use HP Software Cleaning Method. CLEAN THE HEAD Hope this helps ======================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 21, 2007
SOURCE:
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
Hp 1200 problem printing block black
sound like a toner problem, try shaking the toner a bit.
Remove toner cartridge, then shake it left to right and up and down(without hurting yourself) then replace the toner and then try again.
If its still giving problem then either the drum is bad or cartridge is defective, try another cartridge to be sure. try to avoid spraying air in the printer as toner might adhere to the printhead causing more problems use a vacuum.
Good luck. Wish they have a option to post picture of problem area's on these post its best to see the problem or a sample of the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Feb 14, 2013 | HP LaserJet 1200 Printer
I get a vertical black line on my printout, from my HP 1200 laserjet. Can you help?
May b your printer needs some servicing.
The black line may be caused by a faulty or used fusing film or fuser roller.
Mar 15, 2010 | HP LaserJet 1200 Printer
HP Business Ink-jet 1200 1) when it starts printing and the paper feeds it makes an extremely loud clunk sound regardless of the paper tray being used. 2) each and every time the paper comes through it...
The pickup roller is problematic. First clean, then replace if necessary.
The part should be under $20.
To replace (from HP Support):
1. Unplug the power cord from the
printer, and allow the printer to cool.
2. Open the toner cartridge door, and
remove the toner cartridge.
3. Locate the pickup roller.
4. Release the small, white tabs on
each side of the pickup roller by
pushing them away from the roller,
and then rotate the pickup roller
toward the front.
5. Gently pull the pickup roller up and
out.
6. Position the new pickup roller in the
slot of the previous pickup roller.
Note Circular and rectangular pegs on each
side prevent you from incorrectly
positioning the pickup roller.
7. Rotate the top of the new pickup
roller into position until the white
tabs on each side of the roller snap
the roller into place.
8. Reinstall the toner cartridge, and
close the toner cartridge door.
9. Plug the printer in to turn it back on.
Hope this helps.
Aug 16, 2009 | HP Business Inkjet 1000 - Printer - colour...
Hp lj 1200
How much Price HP lj 1200 at Sisney- Astralia?
Aug 16, 2008 | HP LaserJet 1200 Printer
Hp Zt 1200 No screen display
ya i would say onbord video issue
Feb 02, 2008 | Computers & Internet
HP Business Inkjet 1200
sure..there must be something underneath in the tray or paper slots..check carefully..I use a pen light in a darkened room..the white shows clearly then.
Oct 16, 2007 | HP Inkjet 1200dn Printer
HP OfficeJet V40xi InkJet Printer Logo
47 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
