Question about Maytag PAV2300 Top Load Washer
Loud screeching noise on spin cycle
WHEN SPIN CYCLE IS STOPPED THE DRUM STOPS IMMEDIATELY RATHER THAN SPINNING DOWN SLOWLY...ALMOST LIKE THE PARKING BRAKE IS ON. VERY LOUD SCREECHING WHILE SPINNING.
  • Anonymous Apr 25, 2009
    • loud screeching sound when machine comes to rest
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Posted on Apr 21, 2009
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
I have a Maytag Bravos Washer - I have the same problem. It cost as much to change the spin bearing as to buy another washer. Sounds like an airplane landing in my home when it goes on spin cycle.
Remember its whats inside that maters - I will never ever again buy another Maytag!
Posted on Mar 22, 2015
    New Friend:
I have the same problem, but without the drum stopping abruptly. It will slow down then stops. The screeching comes and goes as of now, did you ever find the cause of this problem?
Posted on Aug 26, 2014
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
My kenmore front loading washer is screeching during spin cycle and seems to be spinning poorly at times. what is going on?
The wash drum should spin smoothly by hand without much noise. It is supported with two sets of ball bearings. If the water seal fails, water starts to leak into the inner bearing and they start to rust causing a loud noise especially during the spin cycle. The only way to fix it is to replace the bearings and seal. It a big and expensive job to replace the bearings since you literally need to take your washer apart to get to the bearings. Sorry.
Oct 07, 2010 | Kenmore 44102 Front Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Maytag PAV2300 Top Load Washer Logo
1,773 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
