Question about Acer Aspire 5920-6727 Notebook
Acer5920 can anyone tell me if my acer5920 laptop has bluetooth built in as it has a bluetooth button but when pressed no device comes up on screen.........
  • 211 Answers
No there is no bluetooth device inside.
Acer uses same chassis for other laptops with bluetooth, thats why there is bluetooth button.
Posted on Apr 20, 2009
I would like to know how to connect my bluertooth to my laptop so I can listen to videos without disturbing anyone else?
Assuming you are using windows go to "control panel", "bluetooth devices" add then follow the onscreen instructions, you will have to get your bluetooth device ready for paring the same way you do for everything else.
Not all laptops come with built in bluetooth if your one doesent it will tell you in the setup wizard when you scan for bluetooth device.
Mar 07, 2011 | Computers & Internet
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
Bluetooth
There are six sub models included in the model number you have given and according to the acer website none of the specifications indicate that there is wirelss bluetooth built into the laptop. So it appears that it does not.
Oct 04, 2009 | Acer Aspire 5535-5050 Notebook
Bluetooth config
You can enable it by hitting your windows button on the bottom left of your keyboard and then hitting control panel. From there, go the the blue icon that says bluetooth.
Sep 21, 2009 | Computers & Internet
My acer5920 cant find camera neither what can i do?
If this helps, click on YES below.
You may need the drivers for your camera. Click here.
It looks like there is only a Vista driver on the Acer website
Make sure you select the correct driver for your operating system, ie do you have SP1 installed or not. Read the instructions on-screen.
Select the down arrow next to "Driver and utilities" of your operating system and select the camera driver. Should be something like Camera Driver Bison.
Download to your system, extract to a temp folder and run the 'setup.exe' file.
Jun 28, 2009 | Acer Aspire 5610-4648 Notebook
Have a belkin wireless mouse/nkb(F8E959) which uses a usb dongle
keep the dongle for possible future use. YES! you can use the built in bluetooth card on your computer, just right-click the bluetooth icon at the bottom right corner of you screen on the system tray and choose add device, then a wizard should pop-up. follow the on screen instruction (very straight forward) you might have to press the bluetooth buttons on the keyboard and mouse for the computer to locate or find the devices. then just add them up.
Apr 27, 2009 | Belkin Wireless Keyboard/Optical Mouse...
Aspire 3683NWXCi bluetooth setup
i dont think it has a built in bluetooth module.you may have to put an external one,like a blutooth dongle.
Oct 22, 2008 | Computers & Internet
Bluetooth prolem on acer aspire 5720
welcome to FIXYA
Set up a Bluetooth enabled deviceTo set up a Bluetooth enabled device, you need to do three things:
  1. Add a Bluetooth adapter to your computer.
    This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
  2. Set up the device so that your computer can find it.
    To do this, you must:
    • Turn the device on.
    • Make it discoverable.
    To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer’s website.
  3. Install the device.
    To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
    To install a Bluetooth enabled device
    1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    Click Add, and then follow the instructions.
i hope this helps you out have a good day :)
Jul 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Do i have bluetooth?
Well the Acer site says that it has built-in bluetooth!(Aspire 1690) If you go to device manager (Right click on my computer, click on manage. Under System Tools in the left pane click on device manager) you should see one of the device categories there as Bluetooth, if you don't see it and see a yellow icon that means you might need to install the bluetooth drivers! If you don't either you might need another component(bluetooth hardware) for the bluetooth to work! hope this was helpful regards, babb
May 03, 2007 | Acer Aspire 1690 Notebook
Acer Aspire 5920-6727 Notebook Logo
437 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
