Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Have cleaned unit and will not work. The clean
Have cleaned unit and will not work. The clean filter light is always on but the filter is clean and still not working. The is the ionic breeze Quadra air purifier unit.
  • TuffKitten Apr 22, 2009
    The problem is that the corona wire(s) broke, as already stated. It's REALLY a poor aspect of the design to have the wires exposed like that. Just be lucky you didn't touch them while it was plugged in. They transmit electricity.
    My rear grill is all warped and melted from when one of my corona wires broke. I don't have clue one where to send it to have it fixed.
  • Samuel Charles Spriggs May 11, 2010
    There are two very fine wires running top to bottom inside the unit -- you'll need a good flashlight to see them. Is one of these wires broken? If so, it will need to be returned for service. Don't know if you can still get service on these or not -- I believe Sharper Image is out of business.
    Problem Solver:
  • 4 Answers
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Posted on Apr 23, 2009
I cleaned the whole unit with alcohol, took it apart gently q-tipped it gently and now its working. i am so happy. i love this unit!! thanks for lindaangelo!!
Posted on Feb 16, 2010
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
My sister gave me her Brookstone Pure ion Air purifier....The "clean filter" light flashes red....I wiped the filter with a damp cloth...so think it is clean...?....Is this how to clean it? ....and how do...
Wiping it off won't clean the filter. I submerse mine in hot soapy water ( oxiclean w/any favorite multipurpose liquid cleaner.Let it air dry completely before placing it back in unit.I have tried the dishwasher method and it didn't clean it.I also thoroughly wash all crevices of the unit.If red light doesn't go off, reclean the filter(s). It has all ways worked for me.
Sep 23, 2010 | Brookstone Pure-Ion UV Air Purifier
When clean the filter in one hour the machine stop and i need clean back
clean the metal filter grid blades with a long strip of scotch brite pad and also clean the corona wires in the back of the unit very gently with light grade sandpaper. i had this problem and tried cleaning my unit so many times that i was ready to toss it into the trash. now it works normally. i did some spray painting in the room where the unit was operating and believe it picked up a coating of paint causing the sparking. good luck!
Jul 22, 2010 | Sharper Image Hybrid GP (SI724) Air...
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Quadra - only red light goes on.
In addition to cleaning the plates on the cartridge, also turn the unit upside down then right side up a few times. There are 2 small wires inside the housing, and each has a ceramic ball on it that cleans the wire when the unit is inverted. Also, look through the vents to make sure the wires are not broken. If they are intact, they run in a straight line, almost the entire length of the unit.
If this does not help or the wire is broken, contact The Sharper Image. I believe this unit has a 5 year warranty. When mine failed, they exchanged it for free, even without a receipt.
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
1,984 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
