Drum light flashes yellow
Drum light flash yellow throughout printing
Replace it
Posted on Apr 21, 2009
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
I sprayed dust remover & now the printer won't print. the status light flashes red & the toner, drum & paper lights flashes yellow (hl5250dn)
You may have blown dust or paper shard into one of the optical sensors. These sometimes are used to sense paper position and carriage position. Try cleanig again and pay attention to these sensors.
Sep 01, 2009 | Brother Office Equipment & Supplies
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
HP Laserjet 1300 printer Yellow light flashing
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Jan 28, 2009 | HP LaserJet 1300 Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
Flashing yellow light
Your printer requires a new image drum
Sep 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Bad Print Quality
Are you using recycled toners, as these have a habit of spilling toner out? Take the toner unit out of the drum and look at the green roller in the drum to see if that has the toner marks on it.
Don't hold this unit in the light too long as it can damage it.
Oct 24, 2007 | Brother HL 5140 Laser Printer
1,165 people viewed this question
jasbo
jasbo
