Question about Pit SSR 110CC Pro Beginner Bike
My bike is back firing, how do I fix it?
My bike is a 140 and is back firing and running very roughly
  • 298 Answers
Open the airbox and clean the airfilter. If you have made any adjustments on the carb you may need to retune it as sometimes vibrations can alter them. Also if it has a file line filter check that its not clogged or obstructed in anyway.
Posted on Apr 20, 2009
Over filled tank on my rocket 3 now she is running rough and back firing, all was fine for around five min after starting?
Problem is that you have got blocked breather on tank causing a vacuum stopping the flow either drain some fuel off or have the bike running without cap on
Sep 28, 2013 | Triumph Motorcycles
Motorcycle Trouble Shooting
possible plug cables arcking out.
Apr 07, 2013 | Motorcycles
Yamaha warrior bogs when i go over rough terrain and back fires
When the bike is on rough ground the engine is under more strain so this may be a sign that the spark plug, lead or coil is failing.
Feb 04, 2013 | Motorcycles
My 2007 streetglide back fires a bit and not running smooth.replaced 02 sensor
bike runs good need new speedodometer just tring to se if I am buy correct part now that all the Harley shopes closed
Feb 03, 2013 | 2008 Harley Davidson FLHX Street Glide
When on road bike runs good but as soon as let of throttle back fires through pipes and carbs have changed plugs and rejetted carb was 140 changed to138 all done at a shop
please check for the sparkplug gap setting and also check the carburetor settings........back fires presisit due to uneven plug gap or uneven carburetor fuel setting>>>>!!1
May 06, 2011 | 1997 kawasaki VN 1500 Vulcan Classic
Turn the bike on and fuel comes out of a line behind the air filter. Can you tell me where that line is supposed to go
turn the bike on and fuel comes out of a line behind the air filter. Can you tell me where that line is supposed to go
Dec 15, 2010 | 2003 Yamaha V Star 1100 Classic
2000 honda 1100 shadow spirit. Rough idle, little power.
Replace the spark plug caps and try again. On Honda's the cap is often part of the wire (a dealer part) NGK makes some inexpensive plug caps about $5 each. They should OHM out to 5000 anything above or below and you need to replace them. This should fix the problem.
May 21, 2010 | 2000 Honda VT 1100 C Shadow Spirit
Running rough and backfires
Yes tht could be the carburator since the dirt / fine rust tht settles at the bottom of the tank has found its way in to the carb.
Clean the carbs. and replace the in-line filter.
Water in gas could also be it, since water floats and you had reached the gas to reserve the water may have found its way to the carbs and thus the rough running and back firing .
May 10, 2009 | 2005 Honda VT 750 DC Shadow Spirit
Bike running rough 96 Wide Glide
check plugs and wires, also coil my be weak, sometimes a bad ground will cause this also and weak battery. I've had these problems before on my older Harleys that I built
Nov 27, 2008 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Pit SSR 110CC Pro Beginner  Bike Logo
237 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
