Question about Panasonic KX-T7730 Corded Phone
Meridian 816 key system
I'm swapping out telcom key systems. Removing a Inter-tel Access & installing a Meridian 816 flatpac. The system is used & has very little documentation. I need to find a diagram showing the single 25pr tail punch down for a 66 block configuration. I also need to know if there is a way to add any single line cordles sets to this small system? this was a popular system in the 90's & very dependable are there any software upgrades avalable @ this time.
    Novelist:
  • 201 Answers
These questions are very complex and this forum is not a good place for this type of detail. You should try the tech forum at telbroker.com
Posted on Sep 21, 2007
SOURCE:
EMPLOYEE LEFT US AND WE DON'T KNOW WHAT HIS PASS WORD IS FOR RETRIEVING MESSAGES ON A INTER-TEL 550.4000 TELEPHONE
this can be resolved/password reset by using the Database Programming software provide to you from your phone system vendor.
Feb 21, 2011 | Inter-Tel Axxess Phone 5504400
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Dec 22, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Inter Tel Encore will not roll over
That is not a function of the phone system. You need to call your telephone company and have them configure your lines to hunt
Dec 15, 2008 | Inter-Tel Encore Phone
Inter-tel axxess cabling
Possible loose connection in the telcom room or room jack. Try re-punching all the connections that relate to that phone and test again. No special cables needed for exec. phone, just a single pair as any other.
j
Dec 09, 2008 | Inter-Tel Axxess Corded Phone
I have an Axxess by Inter-Tel phone system and I can not access the system administrator mail box # to get into the system.
This is set up in the phone system programming as to what the mailbox is and the password. If you are not able to get in then you will need to call a technician.
Dec 08, 2008 | Inter-Tel Axxess Corded Phone
Inter-tel ECX 1000
You definitely can do this with a ECX feature set if you program the lines on the keys. You've got to program "Button Hopping" off in the system this automatically puts the first call on system hold when you press the line key for the second incoming call.
I don't think there's a limit to how many you can have on hold.
Oct 23, 2008 | Inter-Tel Encore Phone
Use Special key for feature code
Need to disable SPCL Key Required for feature code entry in system flags, But you may have a numbering conflict in you system with a ext. and a feature code.
Sep 10, 2008 | Inter-Tel Axxess Phone 5504400
Inter-tel Access
You definitely need to have a local phone installation company come in and help you with this. Axxess system setup and programming is extremely complicated for someone that has not worked with it and it requires specific software to make program changes. If you know the company that installed (or services) the system you should call them.
Nov 09, 2007 | Inter-Tel Axxess Corded Phone
Inter-Tel AXXESS T-1 settings
Inter-Tel Axxess uses programming software specific to the version of software in the phone system. So, you need to know what software the system uses. If you do not already have the programming software... it's a huge hassle. The software is only available to Inter-Tel distributors.
Sep 24, 2007 | Lands Phones
Inter-Tel Axxess holding.
In System Timers there is a Hold timer and an Alternate Hold timer. The max that you can extend it to is 255 seconds. Please be advised that this is a system wide timer. If you are the only one that wants this then you should change your keyset to have the alternate hold timer and then extend it to 255. If you want this system wide then you should change the Hold timer and you should be good to go.
Jan 04, 2007 | Inter-Tel Axxess Corded Phone
Panasonic KX-T7730 Corded Phone Logo
99 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
