Question about Dell Latitude C610 Notebook
The monitor will not start for some reason...its plugged in but no image on the screen
Chech for your VGA port.
Posted on Apr 20, 2009
Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
May 24, 2010 | ViewSonic Graphic VG2021m LCD Monitor
My crt monitor has a white ghost image to the right. It looks like JPEG artifacts. I've replaced the monitor and I've tried another graphics card, but it's still there. The PC is an HP d325.
A ghost on your screen is usually caused by a second or reflection of the same image getting into your monitor, and the space between the real image ant the ghost is the delay in time or extra distance the second image travels before it is displayed on your screen. It is usually caused by a defective video cable or a cable longer than usual like 8 feet or more. Also is your monitor plugged into the same outlet as the computer, and is the case on your computer as all are possible reasons for your problem. Some times adding a ground wire from monitor to computer can correct problem. This can be a problem that takes some real detective work to find, and all I can do is suggest some possible causes.
Oct 09, 2009 | Samtron 76df 17" CRT Monitor
Hp 2 2207 monitor problem
You need to update your video drivers. If there is no upgrade, than buy a new video card from walmart for 80.00. This will solve your problems.
Mar 05, 2009 | HP w2207 Monitor
Complete red screen but can still see desktop images clearly
A few possible reasons.
1. Loose or failed video cable. Check that the video (D-Sub or DVI) from monitor to computer is plugged in tight. If you have or can borrow a spare one you can try it to see if its the cables problem
2. Refer to the monitor instructions to adjust the Red Green and Blue settings. Maybe Red is too high or green and blue is too low.
3. If they both don't do anything then the problem could be the graphics card or monitor. Try plugging your monitor in another computer and also try someone eases monitor on your computer.
Sep 29, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor 2 - Image is upside down and backwards
Check your graphic card settings. I have a 6600gt, and can invert my screen. Try going: right click your desktop, select properties. Go the settings tab. Clieck advanced. There do you have a tab for your graphics card? Mine shows I have a 6600Gt. After selecting the tab it displays options. I have NVrotate. That rotates my screen.
Jul 16, 2008 | Computers & Internet
Plugging into a different screen doesn't work
The Cold fusion lamp in your LCD and or the invertor board for the LCD could be bad that is the reason why a faint image . As for the external monitor you should enable it by the Fn+F5/F6/F7 key by pressing it twice at boot up before windows is fully loaded - this to ensure that the external monitor works with your laptop . If the resolution setting and frequency is not comaptible with external monitor you connect then you wont have display on your external monitor . Start windows in safe mode .
May 13, 2008 | IBM ThinkPad G40 2388 Notebook
Averatec screen does not light up
First, plug a external monitor and toggle the screen with ALT+F5. This will determine if the reason of the problem is hardware or software (drivers, configuration, etc).
If the image in the external monitor is correct you probably have a hardware problem with the LCD screen, inverter or cabling.
You can get the replacement parts here and change it yourself:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 12, 2008 | Averatec 6200 Notebook
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Image center drifts, bad keystone, jiggles
Hello, the repair seems possibble to me. One of common reasons for the above mentioned error can be bad soldering (contact). Ask a pro to do the job for you. If you need more info please advice. Arpi
Mar 22, 2007 | Sony CPD 400PS (White) 19 in.CRT...
Dell Latitude C610 Notebook Logo
35 people viewed this question
Alun Cox
