Question about Kenmore Washing Machines
Need to raise the top of a Kenmore 110.20702 990 washer to get to the lid switch.
catriver
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
huuum
  • 750 Answers
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
danromarris
  • 101 Answers
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Posted on Jan 23, 2009
marka19
  • 1430 Answers
SOURCE: Replace "lid switch" on kenmore washer 110-20702-991
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
Posted on May 12, 2010
TheMobilian
  • 8220 Answers
SOURCE: kenmore washer model # 110
That is going to be your lid switch.
On this washer the pump is mounted on the motor. The motor goes in one direction for wash and the other for spin. The water gets expelled from the washer in the spin mode.
Here is 4 videos a service manual and a brief description of how it all goes down:
How it works: Direct drive washer
Posted on Jun 22, 2011
Model 27422300 Kenmore Washer doen't spin or Agitate
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 26, 2011 | Kenmore 22642 Top Load Washer
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite model 110.15962401 . you have to push down hard on the lid for the cycle to start. how can i correct this
Well it means there is some problem in the Lid switch  - If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch.
The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position.
A lid switch price is about $20
Good Luck!!
Thanks
Apr 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Do I have to replace lid switch on Kenmore washer or I can just short the wires? Thank you
you should replace the lid switch if it's broken - if you do clip the wires and tie them together, just remember that the machine won't stop when the lid is raised. it could be dangerous when spinning
Aug 25, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 111 series. the top of the agitator is not working like it should. It does not move. Help
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Mar 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore 110.24622 will not wash, rinse or spin. No noise at all
most washers have a lid safety switch which cuts all power when lid is raised, typically a small "prong" is attached to the lid which fits into a switch in the body of the washer
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load 22292
Check the lid switch. Listen for the clicking sound when you raise the lid. I have found them just loose or out of alignment on some. reply back if you need more help.
Nov 06, 2008 | Kenmore 22422 Top Load Washer
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
I am assuming there is no noise coming from the machine, if not check the lid switch. open the lid and look for a small slot in the top of the washer. With the washer set to run, press down on the slot with a screwdriver or something (make sure everything is clear from the tub) see if there is a clicking sound when you push down. If the machine starts you need a depressor piece on the door. if there is no clicking sound you may need something else. lets start with the simplest, like the door switch and go from there.
Nov 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
