The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
First of all, if you've edited the pictures in any way (opening a picture in a photo editing program and then saving it without making any changes counts as editing) then the camera most likely won't be able to display the images.
You can transfer files (not just pictures) to the memory card using a card reader. Plug the card into the reader and it will appear to your computer as another hard drive. Simply drag-n-drop files to it the same way you copy other files on your computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Sounds like you forgot to use the "safely remove hardware" function when you unplugged the camera.
Try this.. remove the card and battery...press every button....leave it alone for 20 minutes....insert the card and then the battery...turn it on.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )
Supported windows Operating system
Windows 98 Second edition(SE) Windows Me Windows 2000 Service pack 4 Windows XP SP 1 and SP 2
Canon PowerShot A430 has no update about the new driver software for windows 7
Try doing this direct transfer in your computer
1. Connect the camera to your computer using the supplied USB cable of your camera.
2. Set the mode dial to (playback) and turn on the power. The camera and computer will be able to communicate.
3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow]
4. Download the images. * Download the images using the camera or the computer. * By default, the downloaded images are saved into the [My Pictures] folder.
** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another.** Issue on the operating system compatibility.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Charge battery full
Then TAG the pictures with as many tags possible. Up to 10
Make new tags.
then Protect and Favourite the pictures videos etc.
Then transfer again to your "file" on computer. and check for the numbers are continius. Delete the dupl;icates that show with the 2 zeros "00"
Vitally
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You might try putting the pix on a rewritable cd, and then copying them from that drive onto the smartcard drive with your card inserted. Or just try copying directly from your computer file to the smartcard drive with your card inserted, essentially using the computer's hardware to do the job instead of the camera's software.
