Question about Samsung LN32A330 32 in. LCD TV
Spider-like lines run all over screen from impact point
Apparently something struck the screen of the TV and now there are spider-like lines running off the point of impact.
    New Friend:
  • 58 Answers
Sounds like a broken display
the only way to fix this problem is replacing the LCD panel
Sorry to tell you that!!
Posted on Apr 23, 2009
Spider webs behind screen
Pardon me but do you mean the screen has spider web looking patterns all over it? Or are you saying that spiders have crawled into your set and spun webs to catch flies?
If you have a spider web pattern problem then something has impacted your television screen and it is broken. You can check and see if your homeowner's insurance covers this, contact a service provider to see if they want to buy the television for its parts, and contact Mitsubishi to see if they offer a discount or pro rated rate on a new or refurbished television for when things like this happen.
If the problem is that you have spiders in your television I do not recommend vacuuming it out. I have seen people's televisions go out after they attempt to remove dust and webs that way. In this instance I also recommend contacting a servicer and the manufacturer.
Jan 28, 2011 | Toshiba 57HX83 57" Rear Projection...
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
3 year old threw drumstick, and hit the screen small spider web at impact point and vertical colored lines lenght of screen
Unfortunately he has damaged the screen, the only way to fix this is to have the screen replaced, this can cost almost the price of a new TV. If you have home contents insurance you could possible put in a claim for accidental damage.
Jun 24, 2009 | Sony BRAVIA KDL-46V3000 Television
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
I have a big screen 53 inch sony that I never had a problem with until I moved it to anohter house, now there are spider lines in the picture that looks like a lightening bolt, 2 of them, what could have...
Clarification Request by welcomejee, posted on Oct 23, 2008Here you can post snap of spider lines screen ( good focus pic) to understand what exactly problem in TV.
Oct 23, 2008 | Televison & Video
LCD TV REPAIR
physical damage is probably not covered under warranty - check your owner's manual and call customer service - they will advise you [dxh]
Dec 27, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Samsung LN32A330 32 in. LCD TV Logo
175 people viewed this question
Henry  Thomas
Henry Thomas
