Question about Kenwood KAC-8152D Car Audio Amplifier
Amp wont turn on
I have an 1800 watt pyle amplifer. It was working but then i took it out for a couple weeks and was using a smaller 200 watt amp. When i tried to put the pyle back in it wont turn on. Everything works fine and when i put different amps in with the same wires they work. I checked all the fuses on my amp and still nothing. What could be wrong?
  • 298 Answers
Have you checked the remote wire is supply power? try jumping the main power wire t the remote wire to see if it turn on. Also check that your ground wire is securely making contact.
Posted on Apr 20, 2009
Plug your amp up like u normally would then take a smaller wire run it from your ground wire to your negative side of your speaker wire on the amp then it should come on
Posted on Nov 29, 2012
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Amp only runs on 1 channel til it is bridged tried 2 sets of rcas and still the same problem
Either the source isn't moving signal through stereo/both plugs, or the amp is damaged and will need repaired by an amplifier technician.
Jan 14, 2009 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
My pyle amp keeps going into protection when i turn my music up and play it for a min
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
Oct 13, 2008 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Car Audio & Video Logo
156 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
