Question about Garden
Mower deck does not engage
I have a husqvarna YTH1746 and the mower deck does not engage. I replaced the belts and the battery indicator goes negative when I engage the deck.
  • russ francis Dec 13, 2013
    I am guessing you have a short in your PTO wire somewhere. thats the only electrical componant you change when turning on your deck. I would look for somewhere its been rubbed between the switch itself and the deck.,
  • 246 Answers
Hello:
>>Check the Voltage from the Stator/Charging Coils.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>A Bad Stator/Charging Coil will Cause the Problem you Described.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
How to fit the mower deck belt on a ***** LT130?
The best way is to remove the deck from the mower. At this time you should grease the pulleys and spindles. there are four post that hold it. two on either side and one in the front. they are held by cotter pins. lower your deck level down makes it easier. you will have one engagement cable that just pops out it has a spring on it. then slide it out from the easiest side or pick the mower up and pull deck out . at this point it will be apparent where the belt goes and do your your other maintenance of cleaning and lube. factory says lube spindles every 8 hours of use.Then put it back under and re attach.
Sep 15, 2014 | Husqvarna Lth 130 Riding Mower Illustrated...
Grinding noise in mowing deck when engaged
the bearings in one of the blade houseing r going out
Jul 01, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna EZ5424 lawn mower zero turn mower deck will not engage checked fuse checks good where is the electromagnetic coupling located and what is its purpouse?
The electromagnetic coupling is on the bottom of the crankshaft under the mower engine. When the magnets are engaged (power is supplied), they activate the pulley that moves the deck belt.
Jun 22, 2014 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
We just replaced the belt on the deck of our mower. After we reattached the deck, the mower won't start. It won't even turn over. We checked the safety latch on the back of the machine, and it...
First check your battery, it should be around 12.5 volts, if not it is the battery. Because you changed the deck belt, is the mower a manual engaged deck? Make sure the safety switches are working properly. Seat switch, brake switch. When trying to start, do you get 12 volts to the starter? If not, check the 20 amp fuse.
Jan 07, 2018 | Husqvarna Zero Turn Mower Z5426
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Jul 21, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I would like to know the part number of the electric clutch on my Husqvarna YTH1700 mower (42" cutting deck).
went on the husqvarna website and couldn't find a yth with a 42 inch deck - found a yth1746, though and the part number is 532145028
Aug 20, 2009 | Husqvarna Garden
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
