Question about Electronics - Others
Pen drive detection problem
My pen drive is not being detected by any xp system there is no response when it is connected
  • 3 more comments
  • Nani Knight Dec 29, 2007
    I'm using Transcend 4GB pendrive(TS4GJFV30).it is detected by all the computers with WindowsXP, but I have Windows Vista in my laptop and it is not detecting my pendrive.will you please suggest me a solution for my problem.thanksing you.
  • niranjan2588 Aug 01, 2008
    i'm using Transcend 2GB pendrive(TS4GJFV30).it is detected by all the
  • soccorfan Oct 12, 2008
    pendrivedetection
  • mariappanspk Nov 24, 2008
    yes
  • Anonymous Jan 31, 2009
    i have transdence pendrive which is not detected by any pc working on windows XP
Posted on Sep 11, 2009
I'm using Transcand 2GB pendrive (TS2GJFV30). It is detected by all the computers with Windows XP and Windows Vista but It will not display in My Computer and also having some problem related to display containt. Will you please give me a solution for my problem.
Posted on Feb 26, 2009
    Problem Solver:
  • 5 Answers
Follow the procedure listed below to correct your registry:
1. Open Start >> Run, and type "regedit" (without double quotes), and click OK.
2. Locate UpperFilters registry value. it resides in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E980-E325-11CE-BFC1-08002BE10318}
3. Click on Edit menu, and select Delete and click OK.
Note: If you receive an error when you try to delete the registry subkey, you may not have correct permissions to edit the subkey.
4. Locate LowerFilters registry value. It resides in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318}
5. Click on Edit menu, and select Delete and click OK.
6. Exit Registry Editor and restart your system.
We hope this helps to fix the trouble.
Posted on Jan 11, 2010
SOURCE:
Im using v165w pen drive.when i connect to pc its not detecting the USB.i also tried with another pc also,the same problem occurs.i tried with both windows7 and windows XP..Wat can i do to solve the...
If two computers(and two different operating systems) arenot detecting the pen drive then most likely there is something wrong with thatpen drive and it needs replaced.
In Windows 7 you can check the following.
Plug the pen drive into an available USB port.
Click the Windows Orb(Start menu in XP). Right-click on "Computer"(My Computer in XP) thenleft-click "Manage". If "Computer" does not exist in the "Start" menuthen it should be on the desktop.
In the left pane click "Disk Management".
In the right pane, the first column will show you the drives currentlyinstalled(C:, D:, E:, etc). C: is typically the drive your operating system isinstalled on. To check what drive is what, just click the Windows Orb(Startmenu in XP) then click "Computer"(My Computer in XP). If you see the same driveletters under "Computer" that you see in Disk Management then the pen drive isnot being detected. Do you hear any sounds coming from Windows when you plug inthe pen drive? If you have a different pen drive is that one beingdetected? Are other USB devices detected when plugged into thecomputer?
Mar 07, 2011 | Dell Computers & Internet
Pen drive is not detecting
1. Connect your pen drive to some other USB ports present at the rear side of your desktop pc.
2. In case of laptop, try connecting to some other available usb ports and check
3. In still not detected, then test your pen drive in some other systems.
4. If still not working, then it implies that your pen drive got detects.
5. If your pen drive is original kingston then you can claim the warranty from the place where you got it.
I hope this information is helpful for you
Thanks
Mar 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SAN Disk Pen drive detection
you connect your pen drive in your PC that will pop up one window named found new hardware....connect to internet and click on that window....that will ask tom install driver....follow the step and install the software.... restart your PC this problem will get over...\hope bthius will helps you... Thank you.....
Oct 10, 2009 | Express FormTool v5 (1077917SF)
Pen drive not detecting
If you have any other Computer with XP operating System. Connect the Drive. Check if detected then format the drive by checking full format on the menu.
Then connect it the Vista computer and Use it.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 12, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pen drive not opening
What Operating SYstem are you using? XP or Vista? An what service pack? (Check this by pressing the Windows key + the Paue/Break key together)
Firstly, if you are plugging the pen drive in to the front USB, try the USB ports at the back. Many times this works.
Secondly, It's a known problem that XP with SP1 doesn't detect many pen drives correctly.
If that's the case, download service Pack 3 from microsoft's site:
http://www.microsoft.com/downloads/details.aspxFamilyID=5B33B5A8-5E76-401FBE08-1E1555D4F3D4&displaylang=en
HTH,
Deboo
Jan 19, 2009 | Electronics - Others
Cpu won't detect nano pen-drive
I sold the nano pen drive to my friend :-) i just use a kingston pen drive. I think maybe the fujitsu fmv couldn't support/read the nano pen drive "cause i've installed the driver from imation web site but it still won't detect the nano pen drive.
Dec 10, 2008 | Electronics - Others
Kingston 4gb not detected
I dont think this problem is due to the pen drive. It may be more due to the system. Check the driver of the system. This may even happen if the system is affected by virus. So try if your pen drive is getting detected in other computers. If yes, then there may be virus infectiond in your pen drive. So run a virus scan and it may help.
Thanks.
Nov 26, 2008 | Transcend (589307) Media
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Electronics - Others Logo
1,451 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
