Question about Kitchen Ranges
Grill not working
Right element failed and now the left element has failed oven only 3 years old
    Scholar:
  • 192 Answers
This is unusual , I would try unplugging the ellement and plug it in and out a few times . It may be just a bad connection. Try this first. DFD
Posted on Apr 20, 2009
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
The grill (Upper Oven Grill Element) in the oven is not working, I realized the 4 wires at the back that connect to it are all loose. Can i fix it by connecting them myself? is it something dangerous or...
With 4 terminals, it sounds like a double grill element. But it could also be a single grill element with a second oven element. If the spade connecters are loose they need to be tightened first. Get a pair of pliers and gently squeeze the terminals until the gap reduces so when it slides on it will be tight. Do you know what wires go where? If so reconnect them. If you don't do the following;
As you look at the element terminals they should run horizontally. Look at the element inside the grill compartment. From left to right, the no. 1 and no. 4 terminals should be the same element and the no. 2 and no. 3 terminals should be the other element. If this is correct put the 2 neutral wires, in any order, on terminals 1 and 2 and the active terminals on 3 and 4. This should work. You just have to check the correct element comes on when you operate the grill/oven controls.
Feb 18, 2011 | Smeg Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
We have a whirlpool oven with a lower and upper oven which is also the grill. It is about 3 years old and the bottom oven has stopped heating up. The light still works and the fam but has no heat. What is...
If the fan is working o/k, then it is more than likely that the oven element has failed.
This is to be found at the rear of the inner oven compartment behind a removeable cover.
Mar 30, 2010 | Philips Ovens
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Grill element stopped working.
I had the same. Dismantle the oven and see at the back side the connection wires for the heat element. Mostly one of the connectors is faulty. I fixed it that way.
Jul 29, 2009 | AEG MCC663 Microwave Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Grill, top oven and all lights not working after grill element blows
Brinkmann has a terrible customer service dept. You are better off with a new unit.
Jul 30, 2008 | Grilling
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
