Question about Canon MultiPASS F50 All-In-One InkJet Printer
"Wrong cartridge" message.
I reinserted the ink tanks, cleaned the print head with soft cloth, followed the solutions posted and nothing works. Canon F50 Multipass has been doing fine until out of the blue this message popped up. Thank youl
    President:
  • 2,306 Answers
Wrong cartridge means the printhead has gone bad, no amount of cleaning will help. Sorry about the poor advice, but you just need a new printhead.QY6-0034-010 around $45.00
Posted on Aug 12, 2009
I don't know how in the world this worked but it did..on the F50 multipass.
1: Remove Cartridges
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Posted on Apr 28, 2009
My canon pixma mp780 printer is giving the message "wrong cartridge". I did have a non canon ink cartridge in there, but now the cartridges are all canon, and I am still getting the "wrong cartridge"...
1. Remove the front printer cover.
2. Then take out the ink.
3. Next pull up the gray lever and take out the printer head.
4. Now go to the sink and start running the hot water. Then slowly and gently run the hot water over the metal part of the printer head. Use a soft tissue and gently clean the dry ink out.
5. Now dry the printer header with a soft cloth and wait for it to dry before placing it back into the printer.
6. Turn on your printer and see if it works now.
Oct 01, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Re cannon mp730 all in one -I keep getting ?wrong cartridge? error msg. when I followed the solutions that had been posted a month or two ago, removing the cartridge holder, etc. I found that the ink was...
Your print head may be damaged. You might consider replacing it.
Canon suggests pulling the ink wells and also pulling the print head and then reinstalling the whole assembly. They consider this a reset. It is also suggested to replace the printhead which the ink cartridges are housed in. I have done this to remedy bad printing and am considering this $50 purchase as I am dealing with "wrong cartridge" message also. Some have said replacing the printhead remedied this code problem. BUT, i did read one person who said this did NOT work. Right now I am debating whether I should put $50 dollars more into this machine....although this printer has been excellent and many agree.
Comments: Apr 17, 2010 - As a follow up I did fix my "Wrong Cartridge" message by replacing the printhead, I worked and worked at cleaning the old one but finally gave in and anted up the $50. This fixed it! Long live DIYers!
Apr 09, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Hello the following message comes up when i have put some new ink in. U043 the following ink tank cannot be recognised. any ideas? i have tried 2 ink tanks and same message comes up.
This Canon ink tanks has a memory chip.Try clean this chip with piece of cotton and some alcohol.Clean the contacts on the print head too.Sometimes happen this chip going to fail and printer not recognize it respectively not recognized and ink cartridge.In worst case your print head may be defective.
Oct 29, 2009 | Canon MP610 Photo All-In-One Printer
MP730 "wrong cartridge" error
Well...
I can tell you what I did.
I came up with this "wrong cartridge" problem today, searched around the web -- there are a number of ideas -- and then started off on my own.
Perspective: I bought this MP730 in 2003 and have been filling the same set of ink tanks since then. Never had a problem with that. Don't know offhand how many pages I've printed, but I refill the ink every couple of months.
What I did...
I removed the ink tanks and the print head. The print head area was all gunked up with ink as well as the flanges the print head sits on (still in the printer). I DID NOT dunk the print head in water. Something in me says water and electronics is not a good thing. The refill ink package I buy comes with printhead and cartridge cleaner -- smells like alcohol, but who knows. I used that and a combination of Q-tips and kleenex to clean any ink away from the print head and nearby surfaces. I also dripped some cleaner into the print head holes the ink tanks plug into and then dried off the whole print head assembly. I purposely did nothing else. That way, I'd know if I'd found the solution.
I put everything back together and fired it up. The printer cycled itself, removed the "wrong cartridge" message and stood ready for me to print. Finished, right??? Not so fast.
I printed out a Windows test page.....it was totally blank!!! Pause....printed out 2 more.... blank... Uh-Oh.
So, I lifted the lid on the printer, lifted the print head lever, jostled the print head a little to ensure good contact, put everything back together and printed another Windows test page....PERFECT!!!
Note: some writers mentioned cleaning a switch off to the right in the printer. I looked at that area and it IS pretty gunked up. But I didn't touch it to clean it up. That way I had a better idea of what DID fix it. I left it gunked. Of course, maybe all I really had to do was wiggled the print head and put it back together. But at least my print head is clean now. ;-)
So, that's all I did. Don't know if it wil help you, but it's a start.
Dec 26, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Replaced empt 3E cartridge. Now it won't print
Kind of an X-file situation there. You should try an other cartridge, maybe that one is defective
Feb 03, 2008 | Canon PIXMA iP4000R InkJet Printer
Printer Problems
ok" take cartriges out of printer , water on clean cloth make it damp, wipe ink heads, take a pencile with eraser , use eraser on printed circuite on the back of cartidges to clean contacts, use eraser back and forth, wipe with cloth , put it back in the printer . may have to run printer tools to clean cartridges also
Jan 21, 2008 | Computers & Internet
Replacement Ink Gone WRong
AHHH I can help you! you have to reprogram the chip to tell it it has more ink. on the link that I have posted at the bottom here,go to it and scroll to the bottom of the page and you will find FREE software to reprogram your cartridge without buying ANYTHING.its all in the software please rate me FIXYA!if this is what your looking for!
here ya go!
http://www.ssclg.com/epsone.shtml
Nov 18, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
212 people viewed this question
old marine
old marine
