Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
Can't connect to internet on my LG cookie kp500 when i try is says to please check browser settings. I have t-mobile
  • 2 more comments
  • Anonymous Apr 21, 2009
    i use the lg cookie on at&t and when i try to go to the browser it loads for a second the says connection failed? does anyone know why this is happening or how to fix it?
    thanks
  • Anonymous Apr 24, 2009
    same problem here..
    I purchased this phone earlier today and i have changed the settings etc... & put them back & it won't connect says Connection Failed. it tried the sim card that came with the phone aswell it worked once then said Connection Failed!
  • Anonymous May 01, 2009
    Same problem here, MMS doesn't work too.
My kp500 wont connect to internet it says connection failed why is this
Posted on Jul 23, 2010
This worked for me...
http://forums.wireless.att.com/cng/board/message?board.id=LG&thread.id=32470
Posted on May 06, 2009
    New Friend:
When i try to connect to the internet through lg kop500 mobile its say connection failed ,then when i click on ok its being re start,, anyone can help me to fix it...?
Posted on Jul 02, 2013
Aweb
Posted on Apr 27, 2012
  • Ramfixy Apr 27, 2012
    Mywebhost
I had this problem to
what u need to do is go to settings ->profile and make one just enter something and u can go again
hope this helps.
Posted on Mar 12, 2011
Lg kp500 restarts when i back out of my internet bowser
Clear-off cookies & caches from ur browser...... :)
If prob still persists, flash ur cookie; the details for flashing is available from the follg site:http:///www.mylgcookie.com/
Oct 23, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
Internet not work.
The user can surf the internet as the KP500 cookie mobile phone supports HTML/XHTML and WAP 2.0 web browsing technologies, providing speedy connections. The EDGE and GPRS technologies provide not only a speedy service but a good quality of service especially for data transfers. The user can connect their LG KP500 mobile phone with ease to other compatible devices with the USB and Bluetooth with A2DP technologies. The KP500 operates on a Quad-band network and covers GSM-850/900/1800/1900 enabling the user to use the roaming facilities as and when abroad. The LG KP500 supports a document viewer which enables the user to view documents in XLS, DOC and PDF formats.
To Setup the Access Point
  1. Go to the Main Screen
  2. Select Menu (the 4 dot button)
  3. Select the Settings tab
  4. Select Connectivity
  5. Select Access Points
  6. Select Add access point
  7. For the Connection name enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Authentication to This option varies on devices but typically is similar to the setting provided.
    ">#Authentication
  9. For the Username enter The Username for the connection provided by the Carrier.
    ">#Username
  10. For the Password enter The Password for the connection provided by the Carrier.
    ">#Password
  11. For the APN enter Access Point Name - Similar to the server the connection uses for the connection. Different APNs provide different services.
    ">#MMSAPN
  12. Select Save
To Setup the Internet Profile
  5. Select Internet profiles
  6. Select Add profile
  7. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Use proxy to AT&T:
    • On
    T-Mobile:
    • Off
    • Alternative: On
      Note the proxy only needs to be on if using the Alternate settings
    ">#Proxy
  9. For the Proxy server address enter The Server address to use for the connection.
    Some devices require the address in the format of 000.000.000.000. (ex: 011.012.013.014)
    ">#MMSProxy
    if the Proxy is on
  10. For the Proxy server port enter The Port number used by the connection.
    ">#MMSPort
    if the Proxy is on
  11. Set the Access point to the profile created above
  12. Select Save
To Setup the Browser Profile
  3. Select the Utilities tab
  4. Select Browser
  5. Select Settings
  6. Select Profiles
  7. Select Add profile
  8. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  9. For the Homepage enter Can be set to anything if an Internet Plan is on the account such as www.google.com
    ">#Homepage
  10. Set the Internet Profile to the profile created above
  11. Select Save
  12. Select Yes to Activate
  13. The internet should now be configured
Jan 25, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
When going on the Internet a message appears check you browser setting LG PK 500
Hi, messages like (check your browser setting) comes up is because the browser settings enables you to get access to the internet so that you can be able to browse
And it needs to be set for you to be able to access the internet on your phone.
You will need to contact the customers service care center to assist you with the settings of the browser.
Take care.
Aug 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Internet connection
Hi Joanne.
Your Virgin Home network I am guessing is wireless???
This may be a big problem.
The KP500 Cookie is not a WiFi enabled handset so connecting to ANY Wireless internet connection is NOT going to happen. Sorry!
When you search manually for a Network what you are actually doing is searching for another mobile phone network.
The mobile phone network is the only way the cookie can connect to the internet.
Jul 19, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Please Check Browser Settings
U need to first check all the settings to browse internet...... 1) Create ACESS POINT(Settings>Connectivity>Access Points). 2)Create INTERNET PROFILE, with accesspoint as created above(Settings>Connectivity>Internet Profiles). 3)Setting Up PROFILES in Browser, with Intrenet profile created in step 2(Utilities>Browser>Settings>Profiles)
May 22, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
You tube video play on lg kp500
The main problem LG Cookie KP500 has is that it doesn't support YouTube Videos.When you try to watch a YouTube video on its internal web browser, it says something like "File not Supported." So, you can't enjoy YoTtube or any other online streamable videos. So, where's the fun, right?But, now you can watch most of the online videos on your LG KP500, using a browser named"Bolt." Talking about it, its a nice mobile web browser, gives nice speeds, downloader is just satisfactory, you can save pages, hosts a PC like browsing experience and most importantly you can enjoy YouTube, metacafe, google videos etc.So, have fun youtubing on the Bolt Lite browser from your LG KP500.The Bolt Browser for LG KP500 can be downloaded by clicking here.
May 13, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Phone switches off when exiting internet browser.
maybe ur phone just is no working or u need 2 get another one that does not have the internet.
Feb 22, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How can I connect to facebook on my lg cookie phone
firstly u need a gprs (internet settings )in ur mobile then go in web browser type www.facebook.com u r work is done....
Sep 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
4,356 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
