Question about Dryers
I read where the ball bearings can cause this squealing. However, which panel do we access to get to those ball bearings. Kenmore stacked Model No. 417-98802890
    Scholar:
  • 192 Answers
Its vary unlikely that there are any ball bearings at all in the mechanics of that dryer. They have sealed bearings. If one of these were bad it would be more of a vi berating noise or clunk. The belt may be bad, try replacing the belt. if it is not the fix you need it wont be wasted money. Good luck. DFD
Posted on Apr 20, 2009
Squealing sound during spin cycle
Hi, the squealing could be a result of a loose or slack belt or dry bearings, try replacing the belt to see if this cures the problem.
hope this helps.
Feb 13, 2011 | Kenmore 88732 Top Load Stacked Washer /...
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Squealing dryer
Most dryers have a vented access panel on the back on the bottom that is held in place by a couple of screws so you can get to the motor & pully assy. Check to see if the grease has dried up on either the iddler pulley or drive pulley. If needed, push down on the iddler to release pressure on the belt and give the pulleys a spin. If they seem fine then it will be the belt or possibly an overloading problem.
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Mar 07, 2009 | Kenmore Dryers
Kenmore stackable dryer makes squealing sound. need to find out where to get replacement belt. heard people say open it up and replace the belt but we dont know where it opens up.
probably not belt most likely rear drum bearing which means a complete tear down of dryer from front console,rop and front panel will have to be removed then drum will need to be lifted up out of bearing cup belt removed part is avaiable from sears .com or local parts house unit is made by fridgedaire
Dec 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer really squeals
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Sep 20, 2008 | Dryers
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Jan 06, 2008 | Dryers
Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Nov 07, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
