Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Blue screen lg mw60sz12 i have read on the site that you can remove the blue lense i have pulled the tv apart but im unsure which lense it is can anybody help .this tv is out in my shed so if i remove it will i still have a clear tv or not the tv was given to me.they where told it was the globe so they replaced it but still had the same problem then they told her it was going to cost $1000 to fix so she got rid of it .any help would be great thank you
  • Anonymous Apr 26, 2009
    ACE EL INTENTO DE ENCENDEL PERO NO ENCIENDE
  • 175 Answers
It is the optical engine i have just replaced mine for $800au, its a common problem for this model the polarised filters wear out but good luck finding the filters and fitting them it took me 6mnths to find them and i gave up
Posted on Sep 20, 2009
How do i fix the horizontal lines on my tv they are upper left and lower left only
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | LG LM6700 47 in. Cinema 3D Smart TV
Troubleshoot my lg flat screen tv. it turns on but only has a blue screen
Sounds like tuner fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | LG Televison & Video
My LG TV HAS VIRTICAL LINES
There are so many reasons for this fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there. Screen-shots to defective LCDs are given. You can compare it to that of your TVs, and can make sure about the faut.
Mar 26, 2014 | LG Televison & Video
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
LG DLP Projection TV Green/Brouwn vertical Bar
Hi there.
The excessive heat from your lamp has burned one or 2 polarizing lenses.
To replace this you have to pull the optic engine out of the unit and dismantle it.
You will see 3 square lenses in there, remove one by one until you find the burned one.
Then go to ebay and type in hoya polarizing lense.
Buy the 72mm one and cut it to size.
hope this helps.
Sep 30, 2008 | LG RU-52SZ51D 52" Rear Projection...
Philips magnavox 9P6040C104
i just found out why, turn on ur tv and remove back look directly into 3 lenses, if the picture is not nice and clear or looks snowy in all 3 u will not get good color or brightness. I removed my blue tube assembly and took it apart WHILE OUT OF TV. there is cooling fluid between lense and tube, this fluid over time will build a film on the face of the tube and get thick enough to block the tube from projecting picture. (MARK EDGES IT GOES BACK TO GETHERE THE SAME WAY IT CAME APART).Find some new fluid then carefully dissasemble and clean interior of lense, housing and tube thouroughly. Reassemble and fill with new fluid. Do not use old fluid it will be cloudy and snow globe effect. Only do 1 tube at a time this will allow u to realign cross manually as close as possible before u perform convergence. Leave the green for last that is the center and the red and blue are moved to match green. Also be sure to clean mirror and back of screen. Pete
Aug 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Lg 52 inch ru-52sz30 has blue tint
Zenith/LG will fix for free up to 7/1/1/2010. Go to LGservice.com and look for rear projection lawsuit info.
Jun 14, 2008 | LG RU-60SZ30 60" Rear Projection...
Mw-60sz12 parts
Hi there.
I am a service tech.
After reading about the this particular l.g. set i decided to llok into the optic engine and
have found that the blue polarizing lense is crook.
Believe it or not but the set will work fine if you remove this lense, alternatively if you remove the lense
and want to replace it. Go to ebay and type in hoya polarizing lense. Buy the 72 mm circular lense.
Then cut it to size and replace it .
Has fixed many of my customers sets.
Hope this helps.
Jan 01, 2007 | LG RU-52SZ51D 52" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
Computer Repairing
Computer Repairing
