Question about Panasonic Cameras
Panasonic Lumix DMC-T25 When I try to take a picture using any flash mode or on any setting, the flash on the LCD blinks red and will not take a picture. All was going fine during child's birthday party then suddenly started doing this. I have changed batteries but still the same
  • Panasonic Master
  • 19,396 Answers
If you keep getting the problem and you already tried different sets of replacement batteries, then the flash is faulty, usually flash assembly capacitor has blown.
To fix the fault there is need to disassemble the camera and replace the flash assembly, soldering back the new part.
This is a delicate job , and there is risk to cause more damage to the camera instead of fixing the fault.
If the camera is less than one year old , ring the number listed on the user manual to contact Panasonic, to validate warranty , or to ask a quote on repair.
You can get also get a quote on repair from Advance Camera
Posted on Apr 20, 2009
Panasonic lumix problems
Try taking the batteries out for a few minutes. They're may be a second battery for the camera clock and date. If there is, do the same. Good luck.
Aug 14, 2014 | Panasonic Lumix DMC-TS10R 14.1 Megapixel,...
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
My flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
Jan 28, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
How to take high res pictures with the panasonic Lumix 07
Press [MENU/SET] to display the [REC] mode menu & select the item to select. 7M will give you the highest resolution. Hope this helps you.
Please Rank!. Tx
Aug 07, 2009 | Cameras
Hi, I have lost the instructions for my panasonic lumix dmc t25 digital camera. How long should I charge the battery for. Thanks.
I know nothing about this camera, but they are all basically the same. Four or five hours should be quite sufficient if you have no external indication of charging. Cameras often have a flashing light somewhere which stops flashing, or changes colour, or simply goes out.
Jul 10, 2009 | Cameras
The flash on my Panasonic Lumix DMC-FX33 is not working. I did not drop it or anything, but suddenly every picture that should have a flash doesn't. The little screen shows that the flash should go off but...
You camera may be in 'auto'flash' mode, meaning the camera decides if the flash is necessary, depending on the lighting situatioin. Try your flash setting on forced flash instead of automatic, or try it in the dark to see if the flash goes off.
Jun 15, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Lumix pictures blurry
you might have accidently slowed your shutter speed in the settings
Oct 27, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Cameras Logo
65 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
