Question about Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights
Pull chain how to replace pull chain on ceiling light 2 black wires
  • 547 Answers
This is the type of switch that attaches to one wire only do you understand?if connects to live wire to break the conection.
thank you for useing fixya
Please turn off main befor fix
RATE ME
Posted on Apr 20, 2009
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
The correct why to wire up a cieling fan
The usuall wiring for a ceiling fan is black to black, white to white , and red house wire to the other fan wire, sometimes blue. If you only have two wires from the ceiling, then it is still white to white and black to black, but add the other fan wire to the black wires ..
Jun 17, 2010 | Solar 2-wire Pull Chain Light Switch For...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Fix new pull switch to turn on light on ceiling fan
either one all it does is complete the circuit. only one wire is broken to open the circuit when you cut it on and off you just open and close the circuit with one wire.
Jul 29, 2009 | Solar 2-wire Pull Chain Light Switch For...
Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Jun 30, 2009 | Dryers
Replace a pull chain in as ceiling light .i have 2 black wires one goes to the black wire with a lock nut where does the other one go
One black switch wire connects to the hot wire for the lights which is probably blue in color.
The other black switch wire connects to the black wire(s) going to the light bulb sockets.
Apr 20, 2009 | Solar 2-wire Pull Chain Light Switch For...
2 wire chain pull light switch. One blac/one white. which wire goes to which terminal
The gold terminal is usually the "hot" terminal (black wire), the silver terminal is "neutral" (white wire). Remember to turn off the power before you work on it.
Apr 19, 2009 | Electrical Supplies
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
Trying 2 wire a ceiling light
ONE IS NOT REALLY BLACK, YOU NEED TO TEST THE VOLTAGE WITH A VOLTAGE TESTER. tHE TESTER HAS TWO SHICKS PUT ONE ON THE GROUND(GREEN AND YELLOW) AND THE OTHER TO ONE OF THE BLACKS THE ACTUAL HOT WILL SET OFF TESTER. THAT IS YOUR BLACK THE OTHER IS THE WHITE
Jan 07, 2009 | Solar 2-wire Pull Chain Light Switch For...
Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights Logo
354 people viewed this question
Top Solar Electrical Supplies Experts
loft404
loft404
Level 1 Expert
obsteiner
T-Comtech Repairs
T-Comtech Repairs
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
