Question about Dishwashers
My dishwasher does not start when I turn it on.
  • 6 more comments
  • RPFDan Apr 20, 2009
    Is there a picture to show where I look for it at? This is my first dishwasher and really know nothing about the insides of them.
    It's a Frigidaire FDB510LCS3
  • RPFDan Apr 21, 2009
    I looked at the pictures and diagram and it's still difficult. Difficult because whoever installed it when they bought the dishwasher made it practically impossible to pull it out from under the counter. I do however by looking underneath of it see a white electrical cord of sorts that goes from a silver/metal box near the front to the back and then into the floor. I assume that it goes under the house and plugs into something underneath which I will check out tommorrow. Would the fuse be visible looking underneath or should I look for it underneath the house?
    It's not a dead end for me. I will continue to work to get it pulled out from the counter. I cannot see what is keeping it from coming out but I will keep trying. Once I do this, would it be back towards the back of the dishwasher or where exactly to look for it because the pictures are a little unclear to decipher for me.
  • RPFDan Apr 22, 2009
    I have searched my dishwasher for a fuse and do not see one but I have a family member who works with appliances coming by tonight to look at it. However, I e-mailed frigidaire and they said that my dishwasher does not have a fuse. Is that possible or are they just trying to make me have to use a service provider? Please advise.
    I found out today that my Frigidaire dishwasher does not have a fuse. We did however find that the buttons light up but when you turn the knob like I said, nothing happens. So now knowing this, that the buttons lightup but nothing happens when you turn the knob, are we able to narrow it down to what it might be?
  • RPFDan Apr 23, 2009
    Thank you, do you know where I can find a timer at?
  • RPFDan May 08, 2009
    I put the new timer in today and it still does not work. Any other suggestions?
    Installed new timer tonight and it still will not start. Any new suggestions?
  • 15,935 Answers
Your timer has failed.
CLICK HERE to see the part. it is $129.97
it is #3 in THIS DIAGRAM
Very easy to replace!!
Thanks for using FixYa - if you have further clarifications about your question - please use the "continue with expert" option so we are connected later.
Thank You :D
Posted on Apr 23, 2009
  • blueextc3221
    blueextc3221 Apr 23, 2009
    To replace the dishwasher timer...
    Open dishwasher door and removed screws that hold front panel onto access control panel.
    Remove timer knob from from front of dishwasher (Just pulls off)
    and unscrew two screw that hold timer on.
    Unplug timer
    Replace with new timer and everything goes back the same way it was taken apart.
  • blueextc3221
    blueextc3221 May 08, 2009
    The motor/pump unit should be tested for voltage.
    If you have a DMM verify proper voltage at the motor and at the inlet valve.
    Is the timer new?
    CLICK HERE for a diagram of the motor.
    If there is no power to the motor - your next check would be the door latch sensor. If it's not recognizing the door shut - it wont start the cycle. ( i believe this is incorporated in the door latch assembly in your case). CLICK HERE #12
    If you require more help - simply reply.
    Thanks!
    Genius:
  • 1,847 Answers
The issue could be with the following:
  • Door latch. Make sure door is closed and properly latched.
  • Delay start option. If delay start option is available, has it been set and is unit still in time delay before starting.
  • Cycle setting. Check to see if cycle is set correctly (refer to Operating Instructions in the "Use & Care Manual").
  • Check the following the let me know, also let know what is displayed.
    Thanks
    K
    Posted on Apr 22, 2009
      Genius:
    • 1,689 Answers
    Hi RPFDan,
    thank you for using fixya.
    what is the brand and model of your washer?
    With regard to your issue on your dishwasher not turning on, there is a strong possibility that the fuse for its power supply may have been broken.
    The fuse of dishwashers are usually located near the power supply (where your cord goes out off the appliance and to the outlet), this can easily be replaced, and most brand's fuses are available in stores like walmart, radioshack, etc.
    should you have other questions, please do not hesitate to let me know.
    regards,
    voodoo
    Posted on Apr 20, 2009
    • marlon john madrid
      marlon john madrid Apr 20, 2009
      thank you for replying RDFDan,
      The model's interface was actually different for every year model, but I was able to get some pictures where you may locate the fuse.
      You may see dryers, washers, but the circuit of fridigair is almost the same for every applicance.
      http://www.american-appliance.com/images... (Far right)
      http://applianceguru.com/hello/293001/10... (right upfront)
      http://applianceguru.com/hello/293001/10... (far left)
      http://media.photobucket.com/image/Frigi...
      http://img101.imageshack.us/img101/5822/...
      http://www.applianceaid.com/images/ldrwh...
      http://c.searspartsdirect.com/lis_png/PL... (number 45 part)
      hope this helps, feel free to accept the answers, if you have other questions, just let me know.
      regards,
      voodoo
      marlon john madrid Apr 21, 2009
      wow, it sure looks like the washer was wall / floor mounted. worst part is if the mounts and attachments are rounded up and there is no physical way to have it dettached.
      the chances of us locating the fuse underneath is 1/20, because like what i said, the interfaces are different.
      having the washer removed from its mount is still the best way to locate the damaged part and have it replaced.
      my apologies for a possible dead/end until there is a way for us to free the washer. you may accept the answers to your question as desired, im looking forward to working with you again or having this matter fixed.
      regards,
      voodoo
    • 527 Answers
    Sir,
    Some of the first things to check would be, did the water accidentally get turned off to the dishwasher? You need a volt meter to check for voltage at the fill valve, then go from there. If you have voltage to the fill valve, than the valve is bad, provided you have water pressure to the dishwasher. If you do not have voltage to the fill valve, then the wiring needs to be traced back to the control board and check for voltage there. The overflow switch could be bad also. Also check the door switch(es). If there is a cancel/drain function, try that with the door closed. If it operates, then the door switch(es) should be good.
    • Door latch.
    • Cycle setting.
    Thanks Good Luck
    Appreciate to rate as "Fixya"
    Posted on Apr 21, 2009
    Resetting computer on kdte204dss0 Kitchenaid
    The most common reset for the dishwasher is:
    1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
    2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
    3. After that, press the Pause / Cancel / Stop button twice to clear the display.
    4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
    Jul 28, 2016 | KitchenAid Dishwashers
    Our machine is frozen not responding to panel buttons
    You can try resetting your dishwasher.
    Jul 28, 2016 | Dishwashers
    My dishwasher does not power up?
    How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
    www.partselect.com/Repair/Dishwasher/Will-Not-Start/
    When your dishwasher won't start it can be frustrating. ... The selector switch on adishwasher is used to select different options for the individual cycles, such as ...
    Dishwasher Will Not Turn On - How To Fix ...
    removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
    Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check ... My Frigidaire dishwasher Model # FGID2474QFOA is only a year old ...
    Dishwasher has no power - YouTube
    ? 4:38
    https://www.youtube.com/watch?v=pp5P3Cvy9qA
    Mar 26, 2010 - Uploaded by ApplianceHelpOnline
    If your dishwasher has no power watch this video. For more free videos,parts,service manuals, free expert ...
    What to Do When the Dishwasher Won't Start -
    Jan 18, 2016 | Frigidaire Dishwashers
    Dishwasher WHIRLPOOL DU930PWPQ2 stays locked and doesn't start. Even when i push on "heated dry" during 5 seconds. What can i do ? Some one gets an answer ? Thank you
    Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check yourself ... Frigidaire, Kenmore, Whirlpool, and Bosch) work the same way. ... This door switch is also sometimes called a door lock or door interlock switch. ... All the lights light up on my dishwasher but the thing doesn't turn on at all.
    Troubleshooting Why the Dishwasher Won't Start ... - YouTube
    ? 3:58
    https://www.youtube.com/watch?v=8ZrtcdtmyEk
    Jun 20, 2012 - Uploaded by PartSelect
    In this video you'll learn what happens when the dishwasher won'tstart. ... Here are a few things you should check if yourdishwasher won't start: ... Replacing the Thermal Fuse & Harness (Whirlpool #675813) - Duration: 6:01.
    Whirlpool Dishwasher DU930PWPQ2 Troubleshooting ...
    Jan 14, 2016 | Whirlpool Dishwashers
    Siemens dishwasher- start button is flashing but will not start. some water in bottom of dishwasher.
    Did you try turning off the circuit breaker to it, waiting about 15 minutes and turning it back on?
    If that doesn't do it, I would start by checking your drain pump.
    Oct 24, 2014 | Siemens 24 in. SL84A305UC Built-in...
    Whirpool adp 2415
    try turning off the power to the dishwasher for about 20mins then turn the power back on. sometimes this will reset the unit
    May 21, 2014 | Whirlpool Dishwashers
    My dishwasher doesnt start
    1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
    Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
    DIshwasher wont start, flashes pre-wash and was lights
    1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
    Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
    Dishwasher doesn't want to fill
    Hello Dianne...I'll take a shot here.. chances are that the door interlock ( switch ) is disabling the dishwasher from starting.. it may be damaged or disconnected.. and as long as you are sure you have a water supply to the dishwasher,.. that's where I would start...If that switch is NOT made.. the dishwasher will not start... Hope that helps
    Aug 16, 2008 | KitchenAid 24 in. KUDS25 Built-in...
    Ariston LL64 doesn't start
    4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
    6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
    7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
    Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
    Dishwashers Logo
    165 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
