Question about IBM ValueBased iLV200 Multimedia Projector
IBM iLV200 Projector not responding to buttons or connected CPU
The power button can turn the projector on, but not off. Only part of the image appears, and never gets to the searching for source... None of the buttons on top of the projector do anything, even the power button. Once I have the projector on, I have to unplug it to turn it off...
  • 2,236 Answers
Either the control board (under the buttons) is broken, or there is a control lock on the projector and you need the manual to remove it.
Posted on Aug 19, 2009
Epson EMP 500 turning off
I believe that's an overheat problem. Check the fan if it's cooling properly. Make sure the unit is in a cool temp room.
Nov 01, 2008 | Office Equipment & Supplies
The projector is ceiling mounted and connected to an HP computer which is running from a network. When the projector is turned on with out the computer or connected to a DVD the position and size of the...
On the remote control of the projector, you'll notice an "Auto Image" button (or similar to it). What it does is synch the signal between the PC and projector. You might also want to check the keypad of the projector, normally there's an Auto button on there also.
Sep 13, 2011 | Epson PowerLite 3LCD Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
No image appear
does your projector detect on ur machine !. your machine recoganize it or not !. ensure the vga cable is ok.if everything is ok then if you can open the projector then check the power unit inside and the voltages applied to the processing unit. this is sometimes due to low voltage or power supply problem.the lamp and controller unit are different from each other. there must be a switiching problem inside. if you can open it then well n gud otherwise u have to take it to the service centre......
Feb 12, 2008 | ASK Proxima C170 Multimedia Projector
Electrical Problem? Projector works, but buttons don't.
IT MUST HAVE THE CARD INSIDE THE PROJECTOR WHICH IS DETACHABLE LIKE MEMORY/PCMCIA OR ANY OTHER. CHECK USB ALSO.
May 23, 2007 | Sharp Notevision PG-C30XU Multimedia...
IBM ValueBased iLV200 Multimedia Projector Logo
106 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
