Printing with generic cartridges
Generic cartridges for z1300 lexmark wont let you print without ordering genuine lexmark, is there a way around this,
  • 228 Answers
Lexmark International does not recommend the use of third party inks or inkjet cartridge refill kits. Genuine Lexmark inks and cartridges are perfectly matched to the printing system. Using genuine Lexmark ink and cartridges ensures that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer.
Lexmark cannot assure the excellent print quality and reliability of its inkjet cartridges after a cartridge has been refilled. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Inkjet cartridges and printer failures caused by refilling or a third party ink are not covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
Please use genuine Lexmark cartridges for best results.
Posted on Apr 21, 2009
No print with new cartridge on z1300
Try to remove and re-insert the cartridges into the printer carrier and make sure they are firmly inserted into the slot. Try to print again.
Print quality issues can be due to dirty or clogged cartridge nozzles. Try to open the Lexmark Solution Center on your computer to clean the cartridges.
On your computer, go to Start menu > Programs > Lexmark 1300 Series folder > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
Oct 28, 2011 | Lexmark Z1300 InkJet Photo Printer
I have a Lexmark Z1300 printer. The cartridges are half full or full and the printer sounds like it's printing, but the page is blank.
Make sure you are using the correct cartridges for your printer. Try to remove your cartridges from your printer. Close the cover. Unplug and replug your printer into th power source to reset it. When the printer turns on, reinsert your cartridges. If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer -> From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A page will then be printed, forcing ink through the print cartridge nozzles to clean them.
Mar 27, 2011 | Lexmark Z1300 InkJet Photo Printer
Just put new ink cartridges in, but yellow is out. Do I need full yellow cartridge in order to print? Printer is not printing.
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 25, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Black ink cartridge wont print
What Brand is it?????
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Mar 21, 2010 | Epson Office Equipment & Supplies
My NX400 doesn't print. I changed original 69 type cartidges with bought on ebay self-resetting 88 type.Printer did resetting but doesn't want to print, actually prints but without ink, copies without ink....
Do not use Resetter.......
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 07, 2010 | Epson Stylus NX400 InkJet Printer
Has been playing up for a while now. Looked like
Feb 06, 2010 | Epson Office Equipment & Supplies
Can I print a document without color ink?
Jan 31, 2010 | Epson Stylus Photo R300 InkJet Printer
Brother MFC-440CN USB Printer double prints letters
Did you use Brother Genuine Cartirdges????
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine.
When they see it’s Generic Cartridges, it will print lines thru the words, mis-align the letters & put stripes across the picture and also do a mix match with the colors.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 30, 2010 | Brother MFC-440CN InkJet Printer
My Epson color printer 880, prints erratic and very small print in a light black and sometimes blue color
Dec 17, 2009 | Epson Stylus 880 InkJet Color Printer
Wont print black or yellow ink
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
Dec 16, 2009 | Epson Stylus C64 InkJet Printer
143 people viewed this question
jasbo
jasbo
