Question about Hitachi UltraVision 55HDS69 55 in. Plasma TV
Hitachi 55hds69 no video or sound
The blue light ont the front flashes 7 times then turns steady after a few minutes it goes orange. I have a service manual and multi meter. I have checked voltages and I have no voltage on terminals CN64 on the power supply also CN63 is missing voltage from fin #8 wich is a power on from main digigal board also CN68b is missing voltage on pins 1 2 3 4 and 5 I am thing main digital board for starters any thoughts suggestions or Help Thanks Kevin
4 Suggested Answers
Basti
  • 1447 Answers
SOURCE: 55hds69 hitachi plasma
First, try the unplug it, wait a few minutes, plug it in trick, several times. If that doesn't work try pressing the power button and slap the back left side of the set several times. Sometimes, this will shock the ballast and/or lamp into working.
Try checking the wires as well if its pinch or not and try to take out all cables from other devices from the back
Posted on May 14, 2008
jdvillanueva
  • 2098 Answers
SOURCE: i have a hitachi 42hds69
May I know if CN63 is the only connector connected to the power supply board before the fuse blew?
Jdvillanueva
Posted on Sep 01, 2011
spr1949
  • 1182 Answers
SOURCE: Power supply board troubleshooting - p50x01au
If you have a service manual, please match the voltages as per that and problems might be in areas where these do not match. But read on what condition these voltages are to be checked, this is usually written in a service manual, i.e, without any signal or feeding some signal etc.
Posted on Aug 06, 2012
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
No sound, no picture.
Hitachi DLP Television Bulb
Most likely a bad lamp. I would replace it first to make sure.
Sep 06, 2015 | Hitachi Televison & Video
When the TV is turned on there is no picture with a verticle line throught the screen. I took the cover off the back and the orange LED light is blinking. The other LEDs are not illuminated.
Hi nikianddonni,
First of all, thank you for posting your question here at Fixya.
I'm assuming here that your TV is Hitachi 55HDS69.
Yes, the digital main board has 5 LED called "knight rider". After "power on" these LED will be turned on in sequence, it may take a few seconds then after the program is loaded without error, all LED will be turned off. All LED should not lit. If some errors occur, it will give an error code through the LED(s).
My first advice is, to unplug the unit from the outlet for at least 1 hour and then check if the symptoms remain the same. If yes, please let me know which LED( D201, D202, D203, D204, D205 ) lit solid/flashing to pinpoint where the fault came from and provide you resolution to fix the problem.
Thank you for your patience...
Jdvillanueva
Dec 26, 2011 | Hitachi 55HDS69 55 in. Plasma Television
The tv cycles on and off
dry soldering on EHT out put side horizontal SEXCTION
Jan 15, 2010 | Hitachi 55HDS69 55 in. Plasma Television
My THOMPSON TV won't turn on!!
Circuit board inside the TV was loose!!
Feb 16, 2009 | Thomson 24WK25U 24" TV
Hitachi UltraVision 55HDS69 55 in. Plasma TV Logo
172 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
