Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Fridge storage fridge is empty not being used for 6 months should i unplug it
  • 10,865 Answers
Definitely unplug it and leave the door open a couple inches for air to circulate. otherwise, when u need it again it will be contaminated with mildew.
Posted on Apr 20, 2009
The fridge in the rental house will be empty and not in use for over a month. Can I unplug it or I should keep it running? Will unplugging it damage the compressor?
No it will not damage the compressor. It is worse on a refrigerator in they loss power and get power back, as in an electrical power outage. Than to leave with no power on. Be sure to leave the door open so it does start smelling.
Feb 04, 2015 | Refrigerators
Tip
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
on Dec 24, 2010 | Refrigerators
I will not use my refrigirator for six months. What shall I do? Unplug the power?
If you are not using it , the power can be dislocated , but you should #1 prop the doors open so that the air can move and dispell any moisture that would otherwise cause odor problems in 6 months time....
a box of baking powder in the freezer and one in the fridge is recomended too.
Mar 23, 2013 | Samsung RB2155SH Bottom Freezer...
Frigidaire fridge stored and unplugged for 6 months. Today I plugged it in again. The light comes on in the fridge but the fridge did not get cold at all. what should I do?
check your setting. it could have be turned off at the control settings. also give it at least 24 to 48 hours to before storing food.
May 02, 2011 | Frigidaire Refrigerators
Fridge is not cooling down. Freezer is fine only the fridge. Plus the water dispenser - water is not that cold
These units like most fridge/freezers, actually cool the freezer first, then a damper opens that flows freezer air into the fridge side cooling it. The thermostat/switch controls the freezer, the refrigerator is controlled with a damper. The cold water storage tank is usually hidden in the bottom rear of the fridge, behind the vegetable bins, so if the fridge is not cold the H20 is also warm. I suggest you unplug the fridge, empty the freezer and remove the covers. Your issue could be a simple ice blockage of the air passage, or a stuck or broken damper control. Use Sears parts to look up a exploded view of your fridge. At minimum, you will learn a bit, and if you end up calling a service guy, he will know he cannot fool you and overcharge you.
Jan 08, 2011 | Cuisinart Private Reserve CWC-600 Wine...
I bought the sz360 electric sisscors for a project cutting up a fleece blanket to make fringe. It worked great. I put it in a drawer for the last 6 mos (not used at all) and,of course, it was dead. ...
Hello. Sometimes batteries need to be completely drained for prolonged storage. But your issue may be different. Here is the link to B&D service, and their batteries&chargers page. Try their toll free and I'm certain they will be able to assist you.
http://www.blackanddecker.com/Batteries-Chargers.aspx
http://www.blackanddecker.com/Customer-Service.aspx
Oct 30, 2010 | Black & Decker SZ360 Cordless Power...
Maytag PBF2253HEW; freezer fan not working and fridge not getting any cold air. Ice maker only dropping about every 6 - 8 hrs. What needs to be replaced? (This was a friend's refrigerator, he used for 2...
Mark Remove the rear panel in freezer. Apply 3n1 oil to fan motor shaft and plug in and spin. I believe they left the freezer shut and the moisture froze the shaft on fan with rust. Once restarted you will be fine. Sea Breeze
Jan 27, 2010 | Refrigerators
The fridge part becomes warm every 6 months. I have to empty the hole fridge, unplugged it and let it thaw with doors open for 72 hours...
Check that defrost heater is working. Pull back wall of freezer out, unplug refrig, unplug defrost heater and check with ohm meter that heater is good. If heater is good then check thermistors are good, if reading correctly, then change mother board.
Sep 30, 2009 | GE Profile Stainless Bottom-Freezer...
Saving Settings
1) Make sure that you use your MP3 Player carefully. Don't drop it. and put it in a safe place. 2) Charge your Player only when its battery nearly empty. 3) leave some storage available, like 10% of your storage. 4) Unplug it from your PC when you aren't using it. 5) Use safe removal when removing it from your PC. 6) When you don't use it, Shut it down. Good Luck
Jun 03, 2007 | Rio Nitrus MP3 Player
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
