Question about Canon PowerShot A530 Digital Camera
Sound on my Canon A530 digital camera
When I record in movie mode, I speak loud enough, but when I play it back, there is only static. Is my camera broken? It's only a month old.
  • 30 Answers
Try ensuring that sound support is on in the menu.
Posted on Mar 25, 2008
SOURCE:
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
I can record in video mode, but I have no sound recorded. What do I need to do? Thank you for your help.
In common case, your video should with sound but it's too low when you play back, you can use the up button to make it loudly, and it will be all right when you play it by your computer
Jun 09, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Mar 11, 2017 | Canon PowerShot SD1100 IS Digital Camera
I HAVE A FE-210/X-775 DIGITAL CAMERA, I TRY TO USE THE VIDEO & PLAY BACK INFO BUT THERE WAS NO SOUND ON THE PLAY BACK HOW DO I GET THE SOUND ON
Unfortunately the camera is not capable to record or playback sound recorded during movie mode as the camera was not designed with any audio speakers.
Apr 17, 2009 | Olympus FE-210 Digital Camera
Video playing in fast forward with no sound
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
No sound when recording video
Did you set up the camera to capture sound? This Camera has a Functions menu which is deep as the ocean, and standard movie capture does not also pick up sound. Additionally, if playing the movie back over an external device, use the A/V cable not USB, and get a High Capacity SD/MMC memory card if you want more than a few moments of video with sound. I would finally recommend an audio input device, as even when in Movie sound capture mode, the volume is never very loud.
Read the advanced manual completely.
Dec 25, 2008 | Canon PowerShot SD1000 Digital Camera
Video
Lizzie,
This may sound like a dumb question, but are you sure that you had the camera set to the video recording mode? Several of the Canon digital PowerShots will show the movie icon on the LCD screen even when the camera is in image record mode. Why, I don't know. Ensure that you set the camera into movie mode by pressing your Func/Set button to go into the Function Menu and then selecting the movie mode that you want to shoot in. Press the Func/Set button again to get out of the Function Menu and you will not only see a movie camera icon on the LCD screen, but also a set of numbers in the bottom left hand corner representing the recording resolution (e.g. 640 pixels) and the frames per second (e.g. 30).
And just in case you did have the camera set in movie mode, make sure that you don't do what many people have inadvertantly done and mistake the video clip for a .jpg image in the playback screen. Videos will of course have the movie camera icon in the upper corner of the image and are viewed by pressing the Set button twice to begin the playback.
If both of these steps were performed properly then your camera may have a hardware issue. As a last resort, try performing a reset from within the menu just to be on the safe side and see if it makes a difference. If not you may need service. Hope this helps.
Sincerely,
HeavyDLB
May 26, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
How to show images on my TV or VCR
Hi connect rca cable to tv , rotate knob to play mode press function set and press play ,now you can view movie.
Jan 24, 2008 | Canon PowerShot A530 Digital Camera
How do i get sound to work in recorded movies
Some cameras you CANNOT play back on the camera, but it only works on the computer. Nothing is wrong, because that camera is basic. So yeah.
Dec 18, 2007 | Sony Cybershot S650 Digital Camera
Movie mode function
The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Canon PowerShot A530 Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
