GE Profile PDW8600J Built-in Dishwasher
Problem for GE Profile PDW8600J Built-in Dishwasher
I have a GE, PDW8600 Series, problem is - no
By jpwexchef on Apr 20, 2009
I have a GE, PDW8600 Series, problem is - no matter how I arrange dishes the top rack always has deposits left on dishes that are on the top rack. The water is plenty hot.
Comments:
Apr 20, 2009
- Some what helpful. Need more information.
Apr 20, 2009
- Deposits is not a film, it is food or other dibri, it can be rinsed off.
Best Solution
posted on Apr 20, 2009
Helpful)
justaskjoe
Rank: Guru  GE Expert
Rating: 85%, 2041 votes
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
GA_googleFillSlot("HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250");
First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions.
If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. For more, see "Dishwasher Doesn't Wash Well."
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra-hot settings, such as "Power Scrub," and use the "Energy Saver" dry cycle.
2) Adjust detergent amount.
3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
More about dishwasher problems & repairs:
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 24, 2009
Somewhat Helpful)
mambro
Rank: Wiz
Rating: 79%, 158 votes
The problem is hard water and not your dishwasher. there is a new product out for this problem and its called the dishwasher filtration system. it filters the water going into your dishwasher removing the minerals that cause these deposits. go to www.dishwasherfilter.com and find out more information about the product. it is guaranteed to work and very affordable also.
Was this helpful?
Yes
No
Popular Solutions for GE Profile PDW8600J Built-in
Questions and Unsolved Problems for GE Profile PDW8600J Built-in
Do you recommend GE Profile PDW8600J Built-in Dishwasher?
Answer
Answer
My GE Profile dishwasher is 3 years old, and has the SmartDispense feature. Over the last month or... (More)
Answer
GE profile dishwasher: my time settings have increased on their own. How do I reset. Ex: quick wash... (More)
Answer
water in the bottom after the cycle is complete.. how do you reset the dishwasher to empty the... (More)
Answer
I have taken my dishwasher apart and cant get it back together.It`s the parts that control the water... (More)
Answer
I have a situation where it does not appear that the soap level in the door (SmartDispense) is not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile PDW8600J Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
