Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
HE error code on an LD-12AW2 dishwasher
I am getting a HE error code on my LD-12AW2 dishwasher and i have no idea what to do with it.
  • Dorothy5 Nov 24, 2007
    We have the error HE on our LG dishwasher model LD-14AT2. Can you help?
    Karen
  • TAKEAHIKE Dec 12, 2007
    I CHECKED MINE AND FOUND THERE IS A RECALL ON THEM. CHECK THIS ON THE QUEENSLAND GOV WEBSITE. RECALL ON LG DISHWASHERS LD12AW2
    Sergeant:
  • 351 Answers
Also check the back of the pcb and see if the plastic case is melting.
Posted on Mar 03, 2008
SOURCE:
Model No. LD-12AW2: control panel flashin PE and not allowing machine to be set or start
The PE error code indicates that the machine has a water pressure sensing error.
Check and clean the filters on both sides of the inlet water line.
Mar 28, 2011 | LG Dishwashers
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
Sep 09, 2008 | LG Dishwashers
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
1,115 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
