Electrolux Dishwasher ESF6150: There is still some water remaining after a cycle has finished, also the display light screen isn't working anymore and neither are the indicator lights. Does anyone know what's wrong and how I can fix this? Thanks.
What is the model number to your dishwasher? Geraldine
ESF6150
I need more numbers then that Geraldine
Model number: ESF6150
Product number code: 911916039
Type: 911D91-2T
I am sorry But i can not help you anymore Geraldine
do you still need help??
SOURCE: Machine won't drain fully
If the drain pump is working fine, and water flows from the machine and there are no clogged drain lines, then the problem is usually the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is too low then that is the problem.
SOURCE: Water Remains in dishwasher after cycle
Few things to check....if it is a push button....press the start button and then press the cancel button, the drain should engage. if it is a timer setup, turn it to the cycle start and close the door, will drain unit. If water doesnt drain and you hear a pump running then you have a clog.....be sure to check your disposal plug,where the drain hose connects to. if water just appears in d/w while not in use check the drain hose position....should loop up from the drain to prevent backwash into d/w.
SOURCE: dishwasher not emptying at the end of its cycle.
Not sure of your light indicator; check the manual. But fyi there should be a little water left in, so the rubber seal doesn't dry out. More than that, and could be clogged drain or bad solenoid, which tells it to open and drain. See: http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
SOURCE: Intake Drain light on and water in the bottom of the dishwasher
sounds like the flood mode is in operation, you may have a leak into the base stopping the wash continuing. pump out the water, then tip the unit at about 45 degrees and see if any water pours out of the base- confirming a leak.
