Monitor fails to adjust-narrow in the middle
I do not have the monitor on this system and no net to it. I have tried to adjust the monitor settings I feel the settings I need do not adjust at all most do work. The screen is narrow in the middle.
  • eimechanical Apr 20, 2009
    No, already tried auto adjust. HP pavilion m70 D5259A The Adjustments I need are the ones that won't work the rest work. It just stopped working one day from the next after I moved it.
  • OnlyOneN
    OnlyOneN May 11, 2010
    What is the make/model of your monitor?
    President:
  • 1,996 Answers
You have to use the OSD (onscreen display) to adjust the vertical height or the horizontal width.
If you have an auto button, try letting it readjust your monitor to the default setting. If this doesn't work, find the geometry setting and adjust the hoizontal or vertical manually to correct the "narrowness".
If this doesn't help, please reply with your monitor make and model number and we'll see if we can sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 20, 2009
  • efs_perpends
    efs_perpends Apr 20, 2009
    What if you change modes, does that give you access to the other settings?
    Please see this link for a guide to the settings for your monitor.
    Otherwise, what happens when you use the select and + and - buttons to move through the menus? Do the buttons not work or are the menus grayed out?
    It may just be that time to bite the bullet and get yourself a flat screen....not such a bad alternative.
    You'll have more desk space!
Monitor display width to wide
You should first check the native resolution of the replacement monitor, then set windows to use that resolution.
Dec 18, 2011 | Computers & Internet
VGA Narrow
Adjusting the Screen Image
Beginning with the Main Menu shown below, use the buttons on the frontcontrol panel to adjust the OnView® controls which display on the screen.
hope this idea/info helps, for further assistance let us know..
micro
Jun 26, 2008 | ViewSonic P220f 22" CRT Monitor
HP f2105 21" LCD Monitor is going to sleep after 2 sec.
Try it on another PC so we can narrow down the problem before taking the monitor apart. Please post back. It can be the setting on your PC, vide card problem, need to narrow down first. I will be working a third one of this model tomorrow and I will upload the pictures of what inside tomorrow.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 17, 2010 | HP f2105 21" LCD Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
My Dell E773c Monitor's image is like a "hyperbola" wider at the top and bottom and narrower in the middle. The Horizontal adjustments do not do anything to correct the problem, Help!!!!
Try to do a factory reset (look up "recall" in the manual, or here: http://support.dell.com/support/edocs/monitors/e773c/EN/ug/setup.htm).
If this does not help, you need to adjust the geometry settings (H/V position, H/V size, rotation, trapezoid, parallelogram, pincushion and pin balance) using the monitor's settings menu. Expect a long afternoon of fiddling around until you get a satisfactory result. A test picture for geometry settings could be of help.
Make sure your computers video setting does not exceed the monitors specification of 1152 x 864 @ 75 Hz.
Feb 04, 2010 | Dell E773C 17" CRT Monitor
Monitor setting panel on permenantly
mrjk65, If monitor still has bright, crisp images displayed on the LCD panel your monitor could be worth saving! Unplug unit from wall outlet and plug it back in! If same problem occurs then most likely problem could be a DC voltage is slightly "out of spec" or a settings panel push switch may have failed. My guess is that when STRANGE out of the BLUE things start to happen for no reason, I would suspect the "switch-mode-power-supply" to be the item at FAULT. Visit YOUTUBE for vids of "LCD monitor disassembly" , "LCD monitor repair" . You will be glad you did. Also try www.ccl-la.com/badcaps.htm , www.lcdparts.net , www.badcaps.net for more info. hope this helps. Bye for now. 12fixlouie.
Nov 08, 2009 | Planar PL1700 17" Flat Panel LCD Monitor
Appearance on monitor is reddish in appearance
Depending on your monitor settings, you should putt all 3 colors on either 0 or 50. whichever is in the middle of the spectrum in your settings. However, when I've seen this problem on monitors, it's been a problem with the cable. Sometimes the cable is tilted, meaning some of the pins aren't connecting. In other cases, missing or bent pins can cause this too. So try to check out both ends of the video cable and adjust it accordingly.
Aug 10, 2008 | Hyundai L90D+ 19" LCD Monitor
Monitor displays vertically
If you mean that your screen display became narrower, then there are usually buttons on the screen to fix this, among other adjustments of the screen. the setting you're looking for has a two way arrow going horizontally through the middle of an icon representing the screen. In case i'm misunderstanding your problem, or this does not help, you can also try to let the screen rest for a while(at least 30 minutes), and turn it back on, to allow it to degauss. Good luck
Mar 13, 2006 | HP A4033A 20 in. CRT Monitor
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
