Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
My Verizon AGT704WG modem/router works fine.
If I take my Verizon modem/router down and replace it with my older and slower Verizon modem coupled with my new T-Mobile WRTU54G-TM wireless router, that router works fine too. I can easily configure both routers when they are "stand alone".
However, to take advantage of my faster Ethernet from Verizon, my T-Mobile wireless router (for my T-Mobile @ home and an unlimited Hotspot service) has to be "downstream" from my new Verizon modem/router. In this arrangement, I can no longer configure the T-Mobile router. Of note, I do have my T-Mobile @ home phone line working -- but, I can't say if the router is firewalled, secure, etc!
Any ideas on how to proceed?
-John from LA
  • 209 Answers
Your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Posted on Apr 21, 2009
I'm trying to set up Wii with a wrtu54g-tm router. will it work? So far no luck. do I need a key?
Yes it will work, and yes you need to know your key (WEP) After you connect you have to download "opera" so you can browse the internet though.
Your network should appear on your TV screen and it will display your network name (SSID). Select your network and click connect. When asked, type in your network key. Your Wii will then connect.
Apr 20, 2010 | Linksys WRT54G-TM Wireless Router
Works with verizon not with com cast
It was working with Verizon. verizon is a DSL company and Comcast is a CABLE company. settings will be different for both the ISPs. Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 13, 2010 | Belkin (F5D5231-4) Router
I can connect the internet on my wii with this
**I m not able to find a snapshot of the router interface. But i ll tell you what all to do there
1) Disable the router's inbuilt firewall
2) Enable DMZ for your Wii's IP address; assign this same IP address on your Wii manually
3) Change the bandwidth of wireless to 20/40MHz
This will surely work
Jan 17, 2010 | Linksys WRT54G-TM Wireless Router
2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Oct 30, 2009 | 2wire HomePortal® 1800HW Router...
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
I can not get a blue light on my router model # WRTU54G-TM
set your modem to a bridge mode and use the PPPoE connection on the router so that the NAT feature on your modem will allow the VOIP connection on your router.
Jan 10, 2009 | Linksys Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Linksys Wireless Router Model No. WRTU54G-TM Router Configuration
Open a browser
type 192.168.1.1 in hte address line, press enter
you should get a prompt for a username/password
Leave username blank
Password admin
this should get you to the firmware configuration.
If you can't access the router, press and hold the reset button on the back for 5 seconds with the point of a pen, then try again.
Jun 04, 2008 | Computers & Internet
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
755 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
