Kirby G4 Bagged Upright Vacuum Logo
Posted on Apr 20, 2009
I need to know how to change my kirby into a blower?
I know the kirby can be changed to a blower, but i dont know how. Any help would be appreciated!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
773
Points
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
How do I change the belt? Thank you for your response.
Kind of hard to find that info, but I did find something that I hope will help you at this URL:
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
If it is of help to you, I would appreciate you going to FixYa and providing me with a rating. Thank you. Paul
tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
How do I change the electric cord on my Kirby vacuum?
Hello, youngh
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about vacuumcleaners and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
15helpful
2answers
I have a kirby g4 how do i make it blow air (instead of suction) - I already attached the hose and the little attachment with a little ending to fit the inflating opening? thanks
Hi There,
Here's a step by step guide explaining what you have to do to change your Kirby from a vacuum into a blower:
Step 1. Make Sure That Your Kirby is Unplugged from the wall. Remove the front nozzle of the machine by lifting the housing that contains the headlight upwards. Now rotate the belt lifter from the green "Belt On" setting to the red "Belt Off" position:
Step 2. With the belt lifter turned to the red "Belt Off" setting, Turn the knob at the top of the bell shaped agitator housing to release the brush housing from the vacuum:
Step 3. Locate the attachment called the saftey cup that attaches on the Kirby in the exact same place as the brush housing did. This part does two things; Activates the safety switch to the left of the fan, and secondly covers the opening to the fan chamber to prevent anything from getting inside the fan housing and damaging it.
Step 4. Once you install the safety cup it is a good idea to check if the vacuum is working. If it is not (assuming it did work with the nozzle) - check if safety cup switch actuator isn't broken (see picture).
If it works then but it does not when you install the hose (next step) you will know that you did not turn the hose far enough.
Step 5. Take the bag off the Kirby. On the bigger end of the hose there is a line that you have to match with a little bump on the kirby fan housing (marked with red dots). Push the end of the hose over the Kirby exhaust as far as it can go.
Step 6. Turn this hose end clockwise (you may have to apply considerable force).
Step 7. It has to be turned far enough to press another safety switch that is on the unit just behind the exhaust neck.
Step 7. You are done and ready to use it as a blower. We would recommend turning it on outside. Hose may have some dust accumulated on the inside and it may blow a lot of dust in the first few seconds of use. Also shake the hose well while outside to loosen any dust/dirt accumulations on the inside.
    Be very careful when blowing dust out of computers or other electronics.
  1. Dirt from inside of the hose may damage components.
  2. Airflow is so strong that it may break circuit boards if they are not well mounted around the perimeter.
  3. Using Kirby a lot of static electricity may be generated that may cause circuit failure due to electrostatic discharge (harmless to people - deadly to electronics).
    NEVER operate blower with the nozzle on. There are 3 important reasons for that:
    1. Kirby is designed to have much higher RPM (Revolutions Per Minute) with the hose or safety cup so it will push more air than with the nozzle.
    2. If you use kirby as a blower with the nozzle - dust and dirt that is in the nozzle from vacuuming carpets and/or rugs will be blown into the air.
    3. If there is nothing (no nozzle no safety cup) Kirby vacuum simply will not turn on.
I really hope that the above instructions were helpful to you in converting your Kirby into a blower. If you have a question on any of the steps, please feel free to use the comment field to ask them, I'm always more then happy to answer any follow up questions you may have.
If this was helpful to you, please be so kind and rate the repair helpful, or by leaving feedback for me. This is really appreciated by the Fixya community when a repair was able to solve your problem.
Thanks again,
Chris Jones
GoVacuum.com
HOW DO YOU CHANGE THE BELT ON THE G5?
Hi There,
Here's a helpful video that we recorded showing you exactly how to replace the belt on the Kirby Generation vacuums, step by step. This video will also show you how to do the basic maintenance on the roller brush to prolong the life of the belt as long as possible.
If you need to still purchase the belt for your Kirby G5, here's a direct link to our website to the belt that your machine uses:
Kirby G4 & G5 Vacuum Cleaner Belt. Kirby Part # 301291A
Here's the video repair presentation:
Please feel free to ask any follow up questions if you need help, I'm always more then happy to answer any question you may have. If you found this helpful, please be so kind and leave feedback, and / or rate my repair helpful.
This is greatly appreciated, and keeps Fixya experts continue posting free repair advice here on Fixya.
Thanks so much,
Chris Jones
GoVacuum.com
The belt is loose on the bottom
Here is the link to the detailed instructions for belt changing. When you take the brushroll out, make sure that the brushroll spins freely. If it doesn't it will burn up your belts and needs to be replaced. (brushrolls available also by using this link)
Hope this helps...
Marci
1helpful
The blower attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Since you lost your manual, you may need belt change instructions as well. Here is a link to my online guide that will show you how....
Hope this helps...
Marci
Kirby G5 vacuum
Here is a link to the help you need,,,
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
