Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
Epson Stylus photo 1400 power kncked out by lightning
I need to know if this printer can be fixed, or if it would cost too much. I believe the power supply problem because I opened it up and replaced a burned fuse, when I plugged it back in the fuse burned out immediately.
Carol
  • Epson Master
  • 419 Answers
I think you can probably guess the answer to this one... If the power supply is blown then it's highly likely that the circuit board in the rest of the printer have taken a hit too.
I'd recommend contacting Epson and seeing if they can offer you a trade in or a refurb, especially if you're under warranty...
Sorry I can't provide more help that's immediately useful.
Posted on May 06, 2009
How to fix Epson photo stylus 1400 are not printing
If the ink is good then this is a throw away printer. No one repairs these, a new one costs less than any part and labor cost.
May 17, 2016 | Epson Stylus Photo 1400 Printer
Epson 545 power supply replacement
hi,
I did the same stupid mistake of plugging the printer into 240V in India recently and I found the solution. Thought of sharing with everyone. Hope this is not too late. The power supply fix is pretty simple. Please look to the side of the printer where the LAN and USB lines are and see the highlighted screw in the below image. Remove that and then just remove the lid carefully to disconnect the power supply to the internal printer units.
This is the other shot from the printer side wise to reveal the exact location of the screw.
Once you have removed the power supply connection to the internal boards, you can simply slide out the power supply out.
Once you have take out the power supply - take it to the near by electronics shop / repair shop and check out circuit. Mine had two blown up capacitors and one IC Chip which costed me about Rs. 150 (INR) with service charge about Rs. 200.
Sep 16, 2012 | Computers & Internet
I have sound but not picture what can be wrong and how do i fix it and at what cost
it seems the on screen display also not there. there are lamps fixed on sides of screen. it lit the screen & u see the picture. either the lamps are defective or their power supply is defective. one can find these after opening the back cover & checking the power supply of lamps. if power supply is defective, it is replacable item. but if lcd panel is defective then the whole panel needs to be replaced. it is a costly item may be it will cost 70% of the price of lcd tv.
Sep 03, 2011 | Televison & Video
Power is not comming into the printer
No power to the printer. 1) Either the power adapter is not connected properly.Remove the power cord from main power outlet and connect it to any other electric outlet.Also at the back of the printer there is a socket where the power got get connected.Remove power wire from there too and reconnect it. 2) If the problem is not solved then there are two possibilities:-- A) The power cord is faulty and needs replacement. B) Or the printer circuit board is got short and it has to be replaced. ------------ In both the cases A as well as B you need to get the fault checked by other spare power adapter or power supply board in printer.At local printer repair shops they have this parts in spare.They will get the fault checked and let you know that which part has to be replaced.Either the power adapter or power supply board.The cost of new power adapter is near to $10 and cost of new power supply board is near to $40. -------------- One more thing i want you to check is.In your printer power adapter there is one three pin power wire is connected.That three pin power wire wire goes from main power outlet to the printer adapter.In some cases that three pin power adapter gets faulty.If that three pin power wire is faulty then the cost of that power wire is just $2.So get that three pin power wire also checked. To see how this three pin power wire looks.See the fig below:--- helpmech_1.jpg
If this wire is faulty then its not much costly. ----------- This are all the possibilities that you will have to get checked.To get the fault confirmed.Thanks.Helpmech.
Dec 04, 2010 | HP DeskJet F380 All-In-One Printer
Epson Stylus Photo 1400 Problem: The counter cannot be initialized by a present firmware. please execute this function again after making the firmware the lasted.
I have fixed this problem I have updated the Epson 1400 firmware and now it world fine. I have downloaded IPL USB SENDER program and new firmware file for 1400 printer and updated firmware. All manuals were included. I found this article - http://www.2manuals.com/1400fw_update.php how to fix firmware problem for epson 1400 and it worked
Sep 05, 2010 | Epson Stylus 1400 InkJet Photo Printer
MANUAL FOR EPSON STYLUS PHOTO 1400 PRINTER
You can download the manual by clicking this link.
Best of luck.
May 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
Printer manual epson stylus photo 1400
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=79609&prodoid=63066043
May 09, 2010 | Epson Stylus 1400 InkJet Photo Printer
Power interrruption over the weekend. HP 4200 won't power on. Outlet, cord, fax and copy machine all work. Is there a reset on this machine?
Sounds like the power supply was damaged. You need a new Low Voltage Power Supply . Local HP repair center can diagnose and repair for you. Kind of tricky to replace as there are many parts to replace and multiple cables routing through different areas of the printer. Easy fix for an experienced technician. Repairing yourself could cause more damage and end up costing more.
Dec 07, 2009 | HP LaserJet 4200 Printer
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
