Question about Pari Proneb Ultra II Compressor Nebulizer System
Sterlize my nebulizer - Pari Proneb Ultra II Compressor Nebulizer System
  • Issy Dunbar-Lamont May 11, 2010
    Which part of the nebuliser do you mean? Can you give me more information please? And I hope I will be able to help.
    Issy
    Problem Solver:
  • 6 Answers
From Pari.com:
What is the best way to clean and disinfect my PARI Nebulizer?
Cleaning: After every treatment, thoroughly rinse the nebulizer to remove medication. Hand-wash with warm water and dish soap. Rinse thoroughly. OR... Wash in the dishwasher using a dishwasher basket on the top rack.
Disinfecting: (done after cleaning) every 2nd treatment day, mix a solution of 1 part distilled white vinegar and 3 parts warm tap water in a clean bowl. Soak the nebulizer parts (except the tubing and mask) for 60 minutes. Rinse thoroughly. OR... Mix a solution using Control III® Nebulizer Disinfectant and soak for 10 minutes. Rinse thoroughly. OR... Boil the nebulizer parts for 10 minutes.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Posted on Jan 19, 2010
  • 105 Answers
Wing Tip™ Tubing Maintenance:
If there is any moisture or condensation in the Wing Tip™ Tubing after the treatment,
let the compressor run with only the tubing attached for a few minutes. The warm air
from the compressor will dry the moisture or condensation in the tubing. Use a damp
cloth to wipe the exterior of the tubing.
Filter:
The Air Filter on the front panel of the PRONEB® ULTRA II Compressor is bright
white. In time, the Air Filter will turn gray, which means it is time to replace it. You
must replace the filter immediately if it gets wet or becomes clogged. The Air Filter
will last for up to 500 hours before replacement. A good general rule is to replace
the Air Filter whenever you replace your PARI Reusable Nebulizer (every 6 months).
To remove the Air Filter, make sure the PRONEB® ULTRA II Compressor is turned
off. Use a coin to turn the Air Filter cover counter clockwise. Pull the cap and filter
out and remove the filter from the cap.. To replace the filter,
press the new filter into the cap with the open end visible. Place the cap and filter
back into the front of the compressor. Use the coin to turn the filter cover clockwise
to tighten.
Note: For filter replacement obtain a new filter, part
#41E4851P12. Do not attempt to wash and reuse the Air
Filter. Do not use substitute filter material. Damage to the
PRONEB® ULTRA II Compressor may result.
Cleaning the PRONEB® ULTRA II Housing and Wing Tip™
Tubing:
Use a damp cloth to wipe the exterior of the PRONEB®
ULTRA II Compressor housing and Wing Tip™ Tubing.
http://www.nationalallergy.com/images/art/Pari-ProNeb-Ultra-II.pdf
Posted on May 05, 2009
Airial nebulizer does not mist
I am very happy to read your articles it's very useful for me, and I am completely satisfied with your website. All comments and articles are very useful and very good. Your blog is very attention-grabbing. I am loving all of the in. turn you are sharing with each one!.... <a href="http://www.easyfit.in" title="Nebulizer" target="_blank">Nebulizer </a>
Apr 02, 2013 | Medline Nebulizer Portable Compressor Sys...
Nebulizer won't put out steam
Make sure compressor is putting out air.
Then make sure funnel looking piece is in the nebulizer cup.
John
Lighthouse Medical
Mar 13, 2013 | Ultra Products Ultra Sonic Compact...
I don't know how to assemble my Medline Portable nebulizer
Feb 16, 2013 | Medline Sport Mist Compressor Nebulizer...
No medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
How do I use my nebulizer in Europe
you can order the adapter here
http://www.boxwave.com/products/plugadapters/american-to-european-outlet-plug-adapter.htm
Jul 30, 2009 | Graham Field John Bunn Neb-u-Tyke...
What face mask would fit on the Evo Sport Neb nebulizer
any "generic" nebulizer face mask will fit this nebulizer (except the Pari brand). There are different sizes so make sure get the correct size to fit you. Usual sizes are infant (child/pediatric) and adult. Usually ask the pharmacy to order if they don't stock it.
Jul 29, 2009 | RTO Evo SportNeb Express Compressor...
Nebulizer filters
Hello annb19702,
The nebulizer you have is made by Invacare Supply Group. You can order online at onlinemedicalsupply.com or you can call them at 1-800 860-0305. Have a nice day. and please dont forget to rate me.
Mike
Sep 19, 2008 | Probasics Rite-Neb Mini Compressor...
PULMICORT RESPULES Support
No, PULMICORT RESPULES, when mixed with other nebulized medications, has not been adequately assessed. PULMICORT RESPULES should be administered separately in the nebulizer.
Aug 27, 2008 | Cardinal Pediatric Nebulizer Aerosol Mask,...
RESPULES Question
No, PULMICORT RESPULES should only be delivered through jet nebulizers. Jet nebulizers are the only effective device for delivery of suspensions such as PULMICORT RESPULES. Because of their physical characteristics, suspended drug particles are generally poorly nebulized in ultrasonic devices.
Aug 27, 2008 | CARE Devilbiss 800C Pediatric Reusable...
Nebulizers question
Nebulizers deliver aerosolized liquid medicine by a facemask or mouthpiece. Successful nebulizer therapy does not depend on significant patient cooperation or coordination. This is useful in the treatment of pediatric asthma, and the NIH recognizes the nebulizer as an effective delivery device for young children.
Aug 27, 2008 | Cardinal Airlife Brand Misty Max 10...
Pari Proneb Ultra II Compressor Nebulizer System Logo
424 people viewed this question
Top Pari Health & Beauty Experts
xalint1
xalint1
 Adam D
Adam D
Level 1 Expert
Are you a Pari Health and Beauty Expert? Answer questions, earn points and help others
