Question about Peavey PVM 520i Professional Microphone
Have a peavey mic with three point lead need to use with my pc
How do i use this mic on my pc do what attachment do i need ?
    Sergeant:
    Champion:
  • 293 Answers
Check the plug on it if it fits the pink jack on the rear side of the pc. If it does not then use a mic jack convertion.
Posted on Sep 21, 2007
SOURCE:
Can i use a peavey PVi2 mic on my peavey renown 400?
No you need a preamp for the microphone found on audio mixers. You will not get good sound from it even if you do buy a mini mixer to provide a preamp for the mic. I would suggest a pa like the ones in this link. Most of them have built in mixers (with preamps) also.
Portable PA Systems Sweetwater com
Apr 12, 2016 | Peavey Audio Players & Recorders
High pitched squeal from powerd speakers
Check to make sure the WIDEST blade of the AC power plug is actually the GROUND (as in "not HOT") in the new location!
Apr 30, 2017 | Peavey Audio Players & Recorders
I have a peavey 8.5c power amp channel one led comes as soon as signal is inputed but,no volume out of channel a very weak
One of the preamp IC's may have failed. They used LM3080N and RC4558 IC's- the 4558 you can use any 4558 as they were all high quality lo noise. The LM3080N may still be available from Mouser, i did not check them. NTE may have a replacement, but not likely to be as quiet as the original.
Even with schematic- which they do not have a provision for me to dupload, You would still end up and either buzz test starting from the output transistors and working back OR putting an audio source on the input and using a high impedance old style headphone like they used to use for ham radio (or modern earbuds connected to an impedance matching transformer low impedance winding and the high impedance winding ) you simply attach one lead to ground and then attach a test lead to the other end of the winding and work your way forward until you lose the audio signal.
Outputs of 4558 are pins 1 and 7, and inputs are 2&3 and 5&6 Do not be surprised if one input goes quiet- if both go quiet you are close. The outputs are the more important test point. These are directly in the audio path and most likely for one to have failed.
Sep 22, 2012 | Peavey Audio Players & Recorders
What kind of batteriers do i need for my peavey modal RQ 200 six channel mini console?
It takes either two or three 9 volt (ick!!!) batteries depending if you want higher phantom power. If you don't use condenser mics, two 9 volt batteries are adequate.
May 31, 2011 | Peavey Music
Useing a Peavey XR 800F Powered PA Mixer/Amp which develops distortion on output after around 60 minutes. Also had gear linked to all inputs at the time, three mics, 2 guitars and keyboard. Any ideas...
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Apr 26, 2011 | Peavey Pv 2600 Power Amplifier
Need mic holder
The Peavey studio pro shock mount for that mic is $50.00. Go to a guitar center and they may have what you are looking for if you don't want the shock mount holder. hope this helps.
http://www.peavey.com/products/browse.cfm/action/detail/item/105225/Studio%20Pro%28R%29%20Shock%20Mount.cfm
Feb 09, 2010 | Peavey Studio Pro M1 Microphone
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Jan 07, 2009 | Shure SM58 Professional Microphone
REVERBERATION
clearer sound = more watts / more power.
amp watts? speaker load/impedence ohms output from amp? those peavey speakers will sound good if they are powered correctly. plus try to keep the mic away from the speakers, which brings me to my next suggestion..... mic??? this will also affect your clarity.
yostamplifier.com
Nov 14, 2008 | Peavey PRO-12 (00497070) Main / Stereo...
Peavey PVM 520i Professional Microphone Logo
156 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Anthony
Don Hart
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
