Question about GE Zoneline AZ55H07D Air Conditioner
Knocking Noise? I have a GE ZoneLine w/heat pump. I hear a knocking that comes & goes. Knocking for about 2mins. then slowly disappears. I checked the fans and they are clear and not hitting anything. Any ideas? My unit is about 8yrs old.
  • GE Master
  • 8,220 Answers
Might be the compressor. It would be a good idea to shoot it with some compressor oil.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 14, 2009
Knocking Noise
Check blowers motor cage under dash sounds like it faulty
Jan 13, 2014 | 2004 Ford Expedition
Car knocking
big ends camshaft water pump
Oct 28, 2013 | Cars & Trucks
Knocking noise when reversing
check your lug nuts. also check the axle shaft joints.
Jan 02, 2012 | Nissan N Z 38 POWER CAT Cars & Trucks
Juwt bought a GE 18,000 BTU window unit from Walmart. It runs very loud outside and you can hear knocking noise inside. what can I do to fix this problem?
Did you remove all the packing materials that may have been inside the unit, before installing it? That may be the knocking noise you hear.
Apr 04, 2011 | GE AGW18DH Electronic Room Air Conditioner
Why do i still hear a knocking noise in the water pump, when i just changed it. also my coolant pressure cap hoes that connects to the radiator blew off while i was driving, why would that happen after i...
Maybe it's not the water pump that is making the knocking noise.
Water pumps generally don't make knocking noises.
It could have a spun camshaft or main bearing if you hear a loud metal to metal knocking noise.
The coolant pressure cap hose that connnects to the radiator:
Is this an overflow hose that leads to an overflow tank? If so, the hose may have a restriction in it.
Aug 07, 2010 | 2001 Dodge Dakota
Loud knocking or tapping sound when engine is cold
THIS NOISE IS PISTON SLAP..MOST NEONS HAVE THIS NOISE..HAVE SEEN THEM LAST FOR A LONG TIME..AS LONG AS IT GOES AWAY,IT SHOULD BE FINE
Mar 08, 2009 | 1998 Dodge Neon
New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Jan 24, 2009 | Ruud UAMB Air Conditioner
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Engine idol knocking noise stalls while holding on footbrake
Hi portop,
Have the valve clearances checked, it could be tappits noise.....Has the vehicle ever been over heated? How's the power output from the engine, has it changed since you've had the vehicle? Does the sound disappear completely, or is the knocking sped up so it's faster and becomes hidden?
I think that it will be a good idea for you to have a technician listen to the engine, to make sure that you don't have a serious problem. Get two or three opinions
best regards Johngee10
Jul 12, 2008 | 1995 Toyota Previa
Need help with GE triton
That knocking noise is probably coming from your water line, and that happens when there is some kind of a ripple/wave effect when the water goes into your dishwasher (DW) thru the inlet/fill water valve. First turn your hot water valve off, underneath the sink coming from the wall and it usually is also going to your kitchen faucet. Then turn the electricity off by locating the breaker to the DW line and turning it off, or if it is plugged in an outlet under your sink, just unplug it. Then take the kick toe panel (panel with 2 or 4, 1/4" or philips screws) from the bottom of the dishwasher. You will then see the water hose, or could be a copper pipe, going into the valve (will have a selenoide, cylinder shape on top and have 2 wires plugged in to it). Unscrew the hose/pipe from the water valve and get a small wide bucket or pot and aim the hose/pipe to it. Slowly have someone open the water valve from under the sink while you hold it in the bucket/pot. If you hear the knocking again, you will need a plumber to check the pipes, hoses and water valve at your wall. If you don't here the knocking noise, just replace the dishwasher inlet/fill water valve part # 785330. http://www.repairclinic.com/0080.asp. Please post back.
Oct 07, 2006 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Zoneline AZ55H07D Air Conditioner Logo
320 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
